Quick adjust turnbuckle replacement?
/ Quick adjust turnbuckle replacement? #1
Haywire
Central Kentucky
Tractorless :(
Is there a replacement for the turnbuckles that prevent the side to side movement of the 3PH lift arms (don't know the proper name for them) that has a quick adjust feature?
I was thinking something like a small ratchet strap but they won't fit in a space that small.
Ian
Edit.... a miniature chain binder would work.
/ Quick adjust turnbuckle replacement? #3
Did you make them or where did you get them?
/ Quick adjust turnbuckle replacement? #4
I made them. I have made 4 other set for other tractors, but the BX was a little harder to get everything just right.
/ Quick adjust turnbuckle replacement? #5
Thanks, that is way out of my skill level and I mean WAY out.
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
Hydraulic Breaker Mini Skid Steer Attachment (A64553)
Hydraulic Breaker...
2007 Polar Dot 407 Insulated T/A Chemical Tanker Trailer (A64194)
2007 Polar Dot 407...
2021 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2021 GMC Sierra...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
