Quick adjust turnbuckle replacement?
/ Quick adjust turnbuckle replacement? #1
Haywire
Veteran Member
Central Kentucky
Tractorless :(
Is there a replacement for the turnbuckles that prevent the side to side movement of the 3PH lift arms (don't know the proper name for them) that has a quick adjust feature?
I was thinking something like a small ratchet strap but they won't fit in a space that small.
Ian
Edit.... a miniature chain binder would work.
/ Quick adjust turnbuckle replacement? #3
Did you make them or where did you get them?
/ Quick adjust turnbuckle replacement? #4
I made them. I have made 4 other set for other tractors, but the BX was a little harder to get everything just right.
/ Quick adjust turnbuckle replacement? #5
Thanks, that is way out of my skill level and I mean WAY out.
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
8ft 3in Teakwood Live Edge Slab Table (A65583)
8ft 3in Teakwood...
2000 Volvo Semi Truck (A66285)
2000 Volvo Semi...
2007 Chevrolet Silverado 1500 Pickup Truck (A64194)
2007 Chevrolet...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
UNVERFERTH 14' FIELD CULTIVATOR (A64278)
UNVERFERTH 14'...
