Questions re Farm Pro 2425
   / Questions re Farm Pro 2425
Hey Guys:
What are the torque specs. on the flywheel, bell housing bolts to the engine and clutch pressure plate on a 2425?
Much appreciated, again.
Ed
   / Questions re Farm Pro 2425 #12
The torque specs are not on the individual tractor components, they're on the actual bolts themselves. Read the bold heads to determine the hardness. Apply torque accordingly.
//greg//
   / Questions re Farm Pro 2425 #13
RonMar said:
Can't help much with the loader question. Some have brackets that unbolt when supported, some will self support or use a kickstand and the pins and hydraulics can be separated easilly leaving just the subframe on the tractor. Mine(custom made) is self supporting I fully dump the bucket and put the bucket edge on the ground. I can then remove the two lift arm pins and remove the control valve from the loader subframe. I then raise the loader/extend the lift cylinders. This rolls the loader forward till the bucket opening is flat on the ground. The bucket with lift arms will freestand like this. Once standing free, I remove the lower cylinder pins, shut off the tractor and take the loader valve out of circuit and connect up all QC's to send fluid to 3PH then startup and back away. It takes a floor jack and some big wrenches to remove the subframe.
Ron
I have a 2425 Farm Pro and it works just like Ron said above. Makes sense after you have done it once, and installes about the same way.
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
2006 Peterbilt 379 T/A Wet Kit Sleeper Cab Truck Tractor (A49461)
2006 Peterbilt 379...
