Questions on oil, hydraulic, for YM240
   / Questions on oil, hydraulic, for YM240 #1
bassfishrman
Alabama
YM 240
I just bought a YM240 and need to know what kind of oil and hydraulic to use.
Also, my front tires have water in them....is this normal?
   / Questions on oil, hydraulic, for YM240 #2
Loaded tires, fronts and rears, are quite common as ballast on tractors.
Your tractor will uses a UTF/JD 303 equivalent oil. This is available nearly everywhere.. wally world.. TSC, and most of the 'big 3' tractor stores have thier brand.. NH m2c134d.. JD and case have hytran and hyguard.. etc...
That's for the tranny, diffy and hyds.. pow steering if you have it too.
Engine oil is a bit less specific.. but many like a 15w40 diesel spec'ed oil. Let your temperature of your environment help you decide onthe crank case oil viscosity.. etc.
Soundguy
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2016 Chevrolet...
Wacker Neuson DT08 (A50123)
Wacker Neuson DT08...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
NISSAN 80 PROPANE FORK LIFT (A53426)
NISSAN 80 PROPANE...
