Question's on a John Deere 425
   / Question's on a John Deere 425 #1
leftybob
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I just purchased a used 96 JD-425 which has the drive shaft drive and also a shaft driven mower. My question is, it seems to take a little more horsepower to power the mower than my JD-345 does. Is this common? It runs great but when the mower is disengaged you get a surge in speed. Also the gas gauge doesn't work but I'm not used to one anyway.
   / Question's on a John Deere 425 #2
I would pull the deck off and check all the idler and spindles for free movement. A seized idler pulley will usually produce smoke (burning belt) but the bearings may be rough or tight. The spindles may need to be greased and/or there may be string or debris wrapped around spindle shaft(s) and dragging on the hub.
   / Question's on a John Deere 425 #3
Surge in speed, meaning rpm of engine??
As mentioned, check the deck...but also check out your Kawasaki...plugs, compression,
My JD 425 doesn't do that..so something isn't right. Hope it is just the deck.
Both tractors have the 48" deck. You may have it right with the govenor. It also looses power when mowing up a slight incline. I want to remove the mower and check bearings and idler pulleys. 345 has the 18hp and the 425 has a 20hp. both water cooled Kaw.
____________________________________________
96 John Deere 425
95 John Deere 345
93 Cub Cadet 1863
83 Ford 1100
51 Ford 8N
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
