Questions for those with a TC35
   / Questions for those with a TC35 #1
LabLuvR
SC
Kubota MX5400
I presently have a Kubota L3710 but am looking at buying a used TC35 with a loader and 4in1 bucket. The attachment I mostly use are 5ft. scarifier/chisel plow, a 6ft. bushhog and a 6ft disc. For those of you who have a TC35 do you use implements similar in size to mine? If you do, how does the 35 handle those implements?
Also, how well does the tractor handle a bucket fully loaded?
Thanks!
   / Questions for those with a TC35 #2
LabLuvR, is this a TC35 or a TC35D as you mentioned in the Buying/Pricing forum? It makes a big difference on ground engaging implements whether the tractor is gear (TC35) or HST (TC35D). Your chisel plow and disc might be a bit much for the HST model, but well suited for the gear model tractor. Since I have no hands-on experience with the TC35 and those implements, I can't offer definitive info, but it will make a difference.
   / Questions for those with a TC35 #3
I use a 6' brushhog behind my TC33D without any problems, that's about 28 PTO HP for the 33 so you'll do fine there. I use a 5' box blade and also 5' tiller without issue. I can fill the box blade to over flow and keep moving but my ground is glacial till so I'm not pulling through soft earth and traction remains good for me. As for the bucket, NH seems to have engineered the hydraulics to match their loaders (or is it the other way around) and I can lift a full bucket. I usually shake the bucket out a little if I'm moving the material far so I don't leave a trail though.
Any chance you could try out your plow beforehand?
   / Questions for those with a TC35 #4
My father-in-law has a Case DX33 (same tractor just red) and I used it with a 6' disk to disk up my yard. It handled it ok and I also have used it with my 6' shredder and his 5' tiller. Like the other post said it handled them well also. This is a hst by the way. He even uses it to run an old NH 268 baler. He claims it runs it better than his Oliver 1650. I don't know about that, but it runs the baler.
   / Questions for those with a TC35 #5
Oh yeah and you have to be careful with a full bucket. I have had it almost standing on its nose. It will lift a lot but must be ballasted.
The one I originally looked at was a 35DT with the hyrdo. But I found another one that is 35 with Shuttleshift. It has a lot less hours and a 4in1 bucket as well. I'm hoping the 35 with Shuttleshift is still availabe. I should know tomorrow. Thanks guys, this helps me a lot!
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
2022 John Deere HD45F Draper Head (A53342)
2022 John Deere...
