Questions for LandedaKioti
   / Questions for LandedaKioti #22
I'm thinking the nice salt air in a shipping container that has no vents. Sun hit's it and moisture can't get out so it becomes humid like a low tide swamp, then it gets dark & cools. Repeat this many times on the dock on the ship and I can see how the copper gets attacked. The sad thing is $1.00 worth of Di-electric grease in those fittings would have prevented all failures to date.
The fix is simple although time consuming. Remove switch, disassemble, soak in White Vinegar for 30min or so. Rinse with water, apply di-electric grease and re-assemble. White vinegar will not harm plastic, so you can soak all electrical connectors without pulling the wires out. Rinse/grease/re-connect. Any time I have a connector apart on any vehicle I own it gets vinegar if needed, then grease.
Believe it or not when a Scuba Regulator is rebuilt this is the exact procedure except only silicone grease is used on the o-rings.
   / Questions for LandedaKioti #23
The pictures of my old switch. When I got the one from the dealer that one wasn't bad as this one. Mine had a break in the white plastic. It is nice to go out turn a key and it turns over. Knock on wood
   / Questions for LandedaKioti #24
When my switch acted up (stopped power to glow plugs when switch rotated to crank position) the problem appeared to be actual dirt/dust that invaded the contact area vs mold and mildew. I cleaned it and lubed that area with dielectric grease but now I wonder if I could/should have sealed against dirt intrusion. Is that even possible with an open key hole?
Does anyone know if/how the new switch is redesigned and will the redesign prevent these problems?
On a positive note, it's nice that the switch fix is so inexpensive and easy to install, IMO.
   / Questions for LandedaKioti #25
Kioti didn't give me a updated switch so I will keep my eye on it. Make me little mad they said the updated switch is for 2011-12 . When the dealer in NJ sold use the rector all the paperwork has it as a 2012 model. What to do.
   / Questions for LandedaKioti #26
How do you know its not a updated switch. What is your serial #
2012 PJFS25 Goose Neck Trailer (A55973)
2012 PJFS25 Goose...
2014 International Derrick Digger Truck (A55973)
2014 International...
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
