Questions about wood chipper on DK5310SE
   / Questions about wood chipper on DK5310SE
I have the same chipper on my ns 5310..you can put whatever you want in that chipper and the tractor won't care..I did have to cut my PTO shaft down and I probably should have raised it up to make the shaft more level but I haven't yet and it ran fine all last season.
Great, thanks. With the quick hitch, I didn't need to cut the PTO & I did raise the base up 1 set of holes to lessen the angle but I agree, it wasn't too bad at stock.
The steel crate that it comes in can be repurposed. I was going to add wheels to the steel pallet and use it as a storage cart for the chipper the garage. It ended up being too tall so I made a cart out of wood with recessed wheels. The upper portion of the crate got converted into a bbq stand.
I saw that suggestion in one of the videos, pretty clever. You bring up a good point about testing the height, I'll make sure to try it first, if not, I have a furniture dolly that might work.
I'm thinking of inverting the upper crate and attaching it to a pallet to use as a firewood box to transport stacked wood, but will need to add some additional supports
6' Pull Cultipacker (A50775)
6' Pull...
KJ 7'x20' Metal Farm Driveway Gate (A53316)
KJ 7'x20' Metal...
air compressor (A55758)
air compressor...
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
Henderson Stainless Steel Salt Spreader (A50775)
Henderson...
John Deere 5065E 2WD Tractor with Canopy (A55302)
John Deere 5065E...
