Questions about my belly mower on 4100, maybe customize it?
   / Questions about my belly mower on 4100, maybe customize it? #1
mikenmichele
J/D 4100
Hi guys. when using my 60" belly mower I cant use my rear 3pt as they both go up and down at the same time. I thought I heard of a kit to pin the belly mower up when I want to use the rear 3pt? The other thing Im considering is converting my belly to rear mount. Has anyone done this? Any pics to share? thanks!!
   / Questions about my belly mower on 4100, maybe customize it? #2
It's called a 'latch kit' I believe. It is basically just two brackets that bolt to the frame, and two turnbuckles attached to a short length of chain. It keeps the brackets that ride on top of the 3ph in the up position.
Converting it to a rear mount would involve a lot of fab work as well as changing the rpm and possibly rotation of the pto.
   / Questions about my belly mower on 4100, maybe customize it? #3
I would get the hydraulic lift kit, then it just uses the rear hyd. remotes for the deck and keeps the 3 point independent.
JOHN DEERE/UNVERFERTH 1700/330 LOT IDENTIFIER 13 (A53084)
JOHN...
Mercury Optimax 150 Boat Motor (A51573)
Mercury Optimax...
2022 LMC H40024 LOT IDENTIFIER 192 (A53084)
2022 LMC H40024...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
New/Unused Agrotk Horizontal Band Sawmill (A51573)
New/Unused Agrotk...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
