Questions about John Deere 790
   / Questions about John Deere 790 #11
NO...., under no circumstances get a 6 foot on the 790. I made that mistake and it scraped both sides of my tires for the past 20 years when I turn..... If you want to try it come by and take mine and you will see...
How does a blade scrape both sides of your tires? Makes no sense. And the moldboard is a long ways from the tires. What difference would it make if it was 5 or 6 feet?
   / Questions about John Deere 790 #12
If you have it angled...
   / Questions about John Deere 790 #13
Would have to be angled sharper than most folks would ever use it. And that depends on the blade design more than the width. I have an 8’ blade that can be spun 360 degrees and the frame holds it well back from the wheels. I would look for a blade with 360 rotation capability.
   / Questions about John Deere 790 #14
Tractor tires are not smooth, so they scrape....and the 6 is inches away, so try to turn and see what happens...
   / Questions about John Deere 790 #16
I've tightened mine to the max and it still swings as the 6 is too much for that size tractor, go figure..
   / Questions about John Deere 790 #17
The 790 is a considerably smaller tractor than your Kubota...and, even with sway links (chains on the 790), an implement can sway quite a bit.
   / Questions about John Deere 790 #18
Reddogs: Show us a pic of the connected 6' rear blade on your 790.
Suspect the sway chains not connected right or the tires set too far out. Might just need some extensions either on the arms or on the blade frame for the 790 (Yanmar tractor I believe).
A 6' rear blade used at an angle will cover the tracks and the end reach out to be able to blade a ditch out. 5' blade, not very possible.
Have had a 6' blade for 50 years and sometimes for grading ditches, wish it were 7'. Originally on my '58 JD 420 2-cyl
   / Questions about John Deere 790 #19
Its similar to this cutter on a 790 as I dont have it attached since it gave me so much grief...
See in the 6th photo, how close the lower links are to the tires, that is what hits against them when you turn on the 6 foot cutter. which isnt helped by the sway chain links as its too much for it to hold tight..
   / Questions about John Deere 790 #20
I think it’s the implement design, not the width that’s the problem. When I shopped for my 8’ blade I wanted one that was designed to be rotated 360 degrees without touching the tires. Some brands couldn’t do this, while some were built for 360 rotation. It’s how long the mounting beam extends from the 3ph. The cheaper brands and models couldn’t be rotated 360 degrees.
LOT OF RIDGE ROW TIN (A58374)
LOT OF RIDGE ROW...
Deere 325G (A57148)
Deere 325G (A57148)
2021 Honda Pioneer 4x4 Utility Cart (A56857)
2021 Honda Pioneer...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
