Grapple questions about choice of root grapple
   / questions about choice of root grapple #1
rbtjr
Piedmont in NC
Kubota MX5800
I want a root grapple for our L3800 38 hp Kubota tractor. We have a 4N1 bucket on the FEL, so we already have the quick-connect hydraulics for the grapple. Our first application for the grapple will be to clean up limbs and other debris left by the logger in a couple of miles of road lanes cut in a first thinning of a pine plantation. I have read several TractorByNet threads about grapples. They are very helpful. Now that I am ready to buy, I have some specific questions I would appreciate some feedback about, especially from owners who have actual experience with the brands I have focused on.
What about size? Our rear tractor tires are 60 outside to outside. That makes me think of a 60 or 54 grapple. The Wildkat Econo grapples are attractive cost-wise but apparently come in 66 or 72 width. I have seen several positive comments about the Wildkat 48 grapple even for pretty large tractors.
What about number and thickness of tines? The North American light duty grapple looks good, comes in 48 or 60? but has five tines. It also has 3/8 wide tines, while the other brands have ス tines.
What about jaw-opening width and depth? The W. R. Long light duty has 48? Wildkat 36? North American 38-40 and CID 32? Except for this, the CID light duty grapple looks pretty good (without knowing the thickness of the tines).
What about the length of the tines protruding past the supporting bar that runs perpendicular to the tines? And what about the depth of the grapple葉he distance from the front end of the tines to the back of the grapple? This distance looks short on the Long grapples.
Any and all feedback would be welcome. Thanks in advance for your comments. Below are the web sites of the vendors I mentioned.
RBG
http://www.wildkatattachments.com/grapple.html
Light Duty Root Grapple | North American Implements
Heavy Duty Root Grapple aka Grapple Rake | North American Implements
Root Grapple
   / questions about choice of root grapple #3
Add construction attachments to your list (just to confuse you more) my dealer recommended I go no bigger than a 60"...he also recommended a model with two top "jaws" (lack of a better term) that clamp down...very interested in what you get, had pretty much decided on a CA but still open to suggestions at this point...
Rich
   / questions about choice of root grapple #4
   / questions about choice of root grapple #5
Stay with 48".... you don't need anything bigger. I used 48" on M7040 and it was the perfect size.
Thanks for the responses so far. I have pretty much decided to go with 60" or less, probably 48", but I am still researching and would welcome whatever additional input anyone is willing to provide. Murphy1244, I went to the Michigan Iron web site. Their units really look strong. I'm going to call them to check them out more. One think about their units is that they have a flat bottom. I'm not sure how that affects anything. Thanks for the reference. Biggreenavalanche, I had CA on my list and failed to include CA in my post.
   / questions about choice of root grapple #8
I have to second Whitedogone. The 48 Wildkat should be perfect for your machine. I have a 4720 (60HP) and it works very well. With 60 horse could I wreck it? Probably but common sense keeps me out of trouble. Great value. I use it for brush, bucking logs and its handled its share of stumps. One of my kids has it now on his 2520 doing clean up-check my avatar and attached pix as I ordered it without Deere hooks and put my own on.
Thanks, Red Horse. Question: I see on the ends of the tines on the Wildkat 48 what looks like flat spears. Most of the root grapples I have seen on the Internet just have the vertical tines and not these little horizontal spear-shaped flat pieces on the end of the tines. Do you like having those "spears" on the tines? Do they interfere if you want to run the tines into the ground a few inches to dig out roots? Also, according to the Wildkat web site the Wildkat 48" opens to 24" and is 31" deep. Is that correct? If so, have you ever wanted a larger jaw opening? Thanks again.
   / questions about choice of root grapple #10
On root rake grapples where you are clearing brush my opinion is that you need the grapple at least as wide as the tractor tires. My 72" root rake grapple is mainly on a 72" wide machine and I could do at times with a 84". Again, this is for brush. If you are using a grapple with the large lower teeth, I would guess much more narrow.
1831 (A51247)
1831 (A51247)
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
Brent 420 Grain Cart (A57024)
Brent 420 Grain...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2017 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52707)
2017 CATERPILLAR...
2019 KUBOTA R630 WHEEL LOADER (A52707)
2019 KUBOTA R630...
