Question what Hydro oil to use???
   / Question what Hydro oil to use??? #1
jrsue
Ventrac John Deere1025R Kioti CK2610
My Ventrac Hydro oil is low and needs topped off. Ventrac calls for Amsoil 5-30 synthetic Hydro trans oil. Does it need to be this specific oil to just top off maybe with a quart?
   / Question what Hydro oil to use??? #2
I don't know that it HAS to be that specific oil but if that's what's in there now it would be best to top up with the same stuff.
   / Question what Hydro oil to use??? #3
Usually it has to meet or exceed manufactures specifications,
it will be difficult to exceed that spec.
   / Question what Hydro oil to use??? #4
Ventrac is a special machine and not cheap. Don't cheap out on the upkeep. I say use what they used. Of course, calling them is your best bet.
Max
   / Question what Hydro oil to use??? #6
   / Question what Hydro oil to use??? #7
If you want to look after it, buy the OEM spec/brand oil for a top up, OR, change the oil completely to one you already carry for your other machines, if it suits the specs. Finding an oil to suit all your machines and using it in everything may be a little more expensive, but not carrying lots of different oils is a bonus.
2020 JOHN DEERE 8370R LOT IDENTIFIER 180 (A53084)
2020 JOHN DEERE...
2023 JOHN DEERE XUV590M LOT IDENTIFIER 65 (A53084)
2023 JOHN DEERE...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
5" & 6" CHANNEL IRON UP TO 20' LONG (A51247)
5" & 6" CHANNEL...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51247)
UNUSED FUTURE BOX...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
