QUESTION: Turf Tires, what are good at?
   / QUESTION: Turf Tires, what are good at?
Will the turfs do ok (any better or worse) than R4's while tilling & plowing?
   / QUESTION: Turf Tires, what are good at? #12
I till with a 5' tiller and I don't think tires matter much as it is at a slow speed and not much pulling. If I was plowing dirt, like using a 2 bottom plow, I would like to use ag tires. It is what they are made for. I use a 7' rear blade to plow snow on level ground. The tires are not loaded and use 4x4 about half the time when the front tires start to plow when turning on greasy snow.
   / QUESTION: Turf Tires, what are good at? #13
Here I'm blowing some heavy drifts for the neighbor with turfs. snowblower1.jpg
   / QUESTION: Turf Tires, what are good at? #14
I'd say as a rule no. If it was pretty dry, turf might do as good, but if its wet even a little, the tread of the turfs tend to load up and stay plugged up.
   / QUESTION: Turf Tires, what are good at? #15
I'm with dodge man on plowing. I had a Bolens G152 with turf tires and it was terrible at plowing. Don't know if I should blame the 2-WD or the turf tires it had. My current TYM233 (4 WD) has the R-4s and it will plow or pull through anything without slipping. I don't have or do snow work, so can't comment on that.
   / QUESTION: Turf Tires, what are good at? #16
This is true...I have Turf tires on my NH...and they are great for everything until there is mud and when the treads load up with mud they just spin...same with any tire though...just takes a bit more mud to load them up...but I have seen R-4's loaded with mud so they were smooth...and stuck.
   / QUESTION: Turf Tires, what are good at? #17
   / QUESTION: Turf Tires, what are good at? #18
Biggest difference I've noticed between R4s (on 1025 now) and R3s (turfs on my 4010) is the R3s bite better in turns. The R4s seem to have a bit more grip on lawn/dirt forward/reverse. You put the major part of those bars perpendicular to the turning circle you're trying to make, you're screwed, even on pavement. If my front R4s give me any trouble whatsoever on this 1025, I'm buying a couple of R3s to replace them. The R3s will chew up dirt/grass more on the turns because they grip and will rip grass.
Ralph
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
White Metal Roof Panels (A55758)
White Metal Roof...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
2013 International WorkStar 7300 AWD Altec AA755 55ft. Material Handling Bucket Truck (A55973)
2013 International...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
