Question regarding use of backhoe hyd. connections
   / Question regarding use of backhoe hyd. connections #11
Thanks again, JJ,
does the order the hoses from the Hoe matter when I connect them to the rear remote?,
I think I'll use the rear remote for now and later,
I'll "T" into the return on the spool with a QC as suggested, then I'll add a QC on the PB from the
loader spool and use those.
I just hope I won't be cutting off some other vital flow thats needed when i do this.
   / Question regarding use of backhoe hyd. connections #12
The flow will be determined by the lever on the remotes.
Which ever way you push the levers, you want to send pressure into the Back Hoe IN hose.
Plug a gage in one of the remote QD's. Then push the lever.
The QD with pressure is the one you want to plug in the BH IN hose. Then bungee that lever position.
   / Question regarding use of backhoe hyd. connections #13
Ok JJ, if I don't "gauge" it, I should be able to follow the hose's for that cylinder and determine
from that, which one is the pressure, can you tell me,,
on a cylinder, what hose "is" the pressure side?
Is it the one at the "base" of the cylinder or the one near the top, where the cylinder comes out?
   / Question regarding use of backhoe hyd. connections #14
A hyd cyl has two pressure ports.
You simply connect the hoses to make the cyl react to your lever movement.
If you want hyd flow when you push the lever fwd, then connect the hose to that QD.
You can loosen one of the QD's to determine which QD has pressure when you move the lever.
   / Question regarding use of backhoe hyd. connections #15
I may have miss-understand your last post,.....
so your saying I should only use 1 of the rear remote outlets, not both?
I connect to one of them and the other hose would go to a tapped "return" line?
I thought I could just plug both lines in one of the rear remotes and one of them would
act a a return.
Here, you said,,
Now if I find the one with pressure like you said, where do i connect the "other" hose from the hoe?
   / Question regarding use of backhoe hyd. connections #16
You can use both work ports if you want, but the BH OUT hose to a return line should have less back pressure.
The BH OUT hose to a return hose also prevents you applying pressure to the BH valve is reverse and perhaps damaging the valve.
   / Question regarding use of backhoe hyd. connections #17
Ok JJ, got it, thank you for your help on this.
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
CATERPILLAR 246D3 SKID STEER (A52707)
CATERPILLAR 246D3...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2010 KMC 3376 Peanut Combine (A55302)
2010 KMC 3376...
Caterpillar 420F2 IT (A53314)
Caterpillar 420F2...
2014 Jeep Cherokee Latitude SUV (A53424)
2014 Jeep Cherokee...
