Question re: Steering Cylinder Seals
   / Question re: Steering Cylinder Seals #11
Thanks for the infromation, very interesting. If the weather warms up I will try the steering wheel test as I think I may have some slippage as the spinner knob will change a little.
PJ
   / Question re: Steering Cylinder Seals #12
<font color="blue"> For example, if the spinner knob is normally at 3 o’clock and you find that it progressively moves around the dial as you mow, this could indicate some “blow by” in the steer circuit. </font>
But it could also be normal. All hydrostatic steering setups have some degree of steering wheel creep, even when they are brand new, since there is no direct mechanical connection between the road wheels and the steering wheel. Folks who are used to power steering on cars and trucks, which do have a direct mechanical connection, sometimes become concerned when they first encounter this phenomenon.
Just thought I would mention it before someone became concerned because his machine has a little steering wheel creep. /forums/images/graemlins/grin.gif
   / Question re: Steering Cylinder Seals #13
I've noticed that my spinner knob isn't always in the same place when going forward. I have no concerns. The thing still responds like it was new.
Agreed...that's why I said "could". /forums/images/graemlins/smirk.gif But if it moves around the dial like I suggested, particularly if it does this each time you use the tractor, then I would bet it's "likely" you have some blow by. In ether case, it’s not really a big deal if it doesn't bother you. And as you note, some blow by is probably normal. If it gets bad, it will be dangerous. But by then, there’d be no doubt that something was wrong anyway. My experience is that it gets progressively worse so there’s plenty of time to take action.
   / Question re: Steering Cylinder Seals #15
marrt,
My steering cylinders are in the beginning stage of sluggishness. I believe this summer or fall I will replace my seals. Did you purchase your seals from Power-Trac? Since they have a $50 minimum order I might have to find another source.
Thank-you,
Dale
Yes, I purchased from PT. In fact, PT makes these cylinders if you can believe it. I don't see how this could be economical but I guess it works for them. The hard part is getting the cap off. It screws off but mine were on really tight.
   / Question re: Steering Cylinder Seals #17
<font color="blue"> And as you note, some blow by is probably normal. </font>
It's my hunch that the normal creep comes from bleed by in the steering valve, not the cylinders -- but it's no more than a hunch.
   / Question re: Steering Cylinder Seals #18
I am a little curious why you think the cylinders are leaking. It could be the steering valve or a priority valve in the steering valve, which lets fluid go to the lift arms if you are not steering. With the engine off, can you make the PT move left or right. At the end of steering, does the steering wheel keep on turning, very slowly?
The main reason I think it’s the seals is because that’s what it was before with the same behavior and that’s what I’m hoping it is this time (because the steering valve is much more expensive). I haven’t tried to move the steering with the tractor off. Before, Terry told me this put a lot a strain on the steering valve and not to try this test more than once or twice. I haven’t tried the end of steering test ether. When it warms up, maybe I should try it.
   / Question re: Steering Cylinder Seals #20
i notice this on the422, it steers better when it's cold.i don't think it's bad enough to worry about yet.
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2014 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2014 UTILITY VS2RA...
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
2016 John Deere Gator (A55973)
2016 John Deere...
