question re Kubota part numbers for rear remotes
   / question re Kubota part numbers for rear remotes #1
edbee
Kubota L4400
Hi,
I want to add rear remotes to an L4400 I just bought (first tractor I have ever owned!). It has a FEL (LA 703) and a backhoe (BH 90). I need to control 2 cylinders on a boom mounted flail mower so don't need valves with float functionality.
I spoke to 3 Kubota dealers and got three different answers as to what parts I need. The one that seems to know what he is talking about the most recommended the following.
Does this sound like it will work?
  • L8303 (QTY 2) 1ST AND 2ND POSITION DOUBLE ACTING VALVE
  • L8561 1ST LEVER BASE KIT
  • L85862A 2ND LEVER KIT
View attachment KUBOTA L4400HST HYDRAULIC REMOTES.pdf
I've attached a parts view I found that seems to support the part numbers but i want to be 100% sure before ordering as I need to get the parts shipped and really don't want to have to deal with returning parts by mail.
Hopefully it all sounds good as I hope to order the parts ASAP and get mowing.
Thanks in advance for any advice you can share.
Ed
   / question re Kubota part numbers for rear remotes #2
Looks good, I did the same on my 4330. I would recommend that you go ahead and add the third rear remote though. You can run hoses from there up to the loader for a grapple if you want to.
I installed mine by myself but it would be some much easier if you had some help, those valves start getting heavy. Be sure that you don't lose any of the O rings between the valves. You can put a little bit of grease on them to hold them in place. Then I would put the bolts in, holding the valves together as one unit
FYI, you will probably notice some leakdown of the cylinders, this is a common issue with the Kubota rear remotes. I had to install some pilot operated check valves on my cylinders.
   / question re Kubota part numbers for rear remotes #3
I agree - those 4 kits (2 valves and 2 lever/coupler/hose kits) should be all you need. The wholegoods kits should include everything right down to the last washer, nut, bolt. o-ring, etc.
If you were to go ahead and order the third remote AND it had float functionality, the float valve may need to be the second of the three in your stack. I don't know this for sure but I noticed on the parts diagram that the lever slots in the trim panel are different lengths with the middle slot being longer (to allow for the extra travel required on a float valve lever).
Thanks guys!
I'll get the parts ordered. I have only had the tractor for 2 weeks and already it has been great help around our small acreage. From pulling out small stumps with the backhoe to relocating a small building. tractors are like the swiss army knife of vehicles.
198367 (A51243)
198367 (A51243)
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
