Question on weighted rear wheels
   / Question on weighted rear wheels #1
FiredudeAT1
Farmall Super A
On the Farmall Super A, is the heaviest wheel supposed to be on the driver's side? Mine is on side of the motor.
   / Question on weighted rear wheels #3
If I remember correctly, my 49 A had weights on both sides.
It has weights on both but side opposite of driver has more. I would think driver side should have more since frame and engine is on the other side.
   / Question on weighted rear wheels #5
If you look at the wheels themselves, the right side should be a cast center wheel about 1-1/2" thick while the left is a pressed type disc balancing out the weight between sides I'm assuming for an average operators weight on level ground. And depends on what the PO mostly used it for. For instance, if they needed a little more weight on the left side for pulling a moldboard plow to keep from spinning, they may have moved the cast center to the left for that reason.
   / Question on weighted rear wheels #6
The "A" I owned was weighted the same on both sides as was the "Super A" my parents had.
Pull Type Garden Wagon (A50860)
Pull Type Garden...
2022 Chevrolet Tahoe FL SUV (A48082)
2022 Chevrolet...
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
Cruise Car Electric Golf Cart (A50860)
Cruise Car...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
