Question on weighted rear wheels
   / Question on weighted rear wheels #1
FiredudeAT1
Farmall Super A
On the Farmall Super A, is the heaviest wheel supposed to be on the driver's side? Mine is on side of the motor.
   / Question on weighted rear wheels #3
If I remember correctly, my 49 A had weights on both sides.
It has weights on both but side opposite of driver has more. I would think driver side should have more since frame and engine is on the other side.
   / Question on weighted rear wheels #5
If you look at the wheels themselves, the right side should be a cast center wheel about 1-1/2" thick while the left is a pressed type disc balancing out the weight between sides I'm assuming for an average operators weight on level ground. And depends on what the PO mostly used it for. For instance, if they needed a little more weight on the left side for pulling a moldboard plow to keep from spinning, they may have moved the cast center to the left for that reason.
   / Question on weighted rear wheels #6
The "A" I owned was weighted the same on both sides as was the "Super A" my parents had.
Load Master 27ft Tri-Axle Boat Trailer (A48082)
Load Master 27ft...
Hyster H40 Forklift (A48837)
Hyster H40...
UNUSED MOWERKING SKID STEER PALLET FORKS (A50460)
UNUSED MOWERKING...
2017 Kenworth K370 New Way 16RLC 16Yd Rear Loader Garbage Truck (A48081)
2017 Kenworth K370...
2013 PETERBILT PB337 SERVICE TRUCK (A50459)
2013 PETERBILT...
Honda 2225CW Gas Blower / Vac (A50860)
Honda 2225CW Gas...
