Ballast Question on top link and rear ballast box
   / Question on top link and rear ballast box #1
surfran
Platinum Member
Finger Lakes Region, NY
Kubota BX1800
Does anyone have a rear ballast box with their BX1800 or BX2200? I just installed mine and it appears the top link is too long as the unit does not sit up straight if the top link is attached. I am attaching a photo with it attached and then will follow one without. Do I need a different top link?
Any help would be appreciated.
Thanks,
And here is it with the top link disconnected and the box sitting on the floor level.
   / Question on top link and rear ballast box #3
From the looks of your photo's, you already have your top link shortened thread wise as far as it will go. My knowledge of top links is pretty minimal and I don't know if they make differant length ones, but they must and it sure looks like a shorter ones is in order here.
Good luck.
   / Question on top link and rear ballast box #4
Hi.....
You might have the older top link? The female part of my top link measures 10and3/4 inches. I can't screw it in all the way and measure it cause its on the tractor with the blade and outside. Hope this helps. George
Mark and George,
Thanks for the replies. I am new to 3-point hitches, so I wanted to see if maybe I was missing something, but you confirmed that I wasn't. I will check into options when I talk to the dealer tomorrow.
   / Question on top link and rear ballast box #6
</font><font color="blue" class="small">( Thanks for the replies. I am new to 3-point hitches, so I wanted to see if maybe I was missing something, but you confirmed that I wasn't. I will check into options when I talk to the dealer tomorrow.
)</font>
Please let us know what he says. I just bought the ballast box to go on my BX2200 but haven't picked it up yet so I'm keen to see how you make out.
   / Question on top link and rear ballast box #7
What happens if you lengthen the lift arm turnbuckles?
   / Question on top link and rear ballast box #8
Good Morning:
I have the same ballast box and it is square and plumb on my 2200. My top link looks a bit different.
   / Question on top link and rear ballast box #9
You have a longer top link than I do mine sits square on the ground with a slight forward lean when fully raised. If you want to poke though a couple a pics go to my Yahoo acc. I can't attach pics from work sorry other wise i'll attach one tonight.
toy pics
hope it helps
cheers
Tony
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52128)
2000 John Deere...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
RoGator RG1100C (A52128)
RoGator RG1100C...
