Question on tires running down roads
/ Question on tires running down roads #1
pizzaguy
Bronze Member
Northwest IA
Kubota L3240 HSTC
I have a Grand L3240 that a friend wants me bring to his place to do some dirt work and landscaping. I have the R4 tires and was going to just drive it over there,which is about 16 miles away on good blacktop roads. Today at Easter dinner the BIL told me that driving that far is really hard on tires. I didn't think that was very far to take it,set cruise and go. My buddy has a car trailer but not sure if it is big enough. Any ideas what a Grand L 3240 w/ cab, loader and rear blade would weigh? Would you just drive it?
/ Question on tires running down roads #2
Your BIL is right, it is hard on tires. We hauled our tractors 4 miles to a field to get up hay. I would haul it if I could.
/ Question on tires running down roads #3
No owner's manual? Tractordata.com will give you the weights. Rent a trailer, if needed, since that much road driving will be hard on both your and the tractor. If you do go ahead, BE SURE IT ISN'T IN 4 WD!!! Assuming no idiot rams into the back of your tractor, probably the worst will be some unwanted tire wear.
/ Question on tires running down roads #4
I figure you get 1500 -2000 miles out of a set of R4's, even less in the front. Do the math, and you probably are looking at a few $$ in tire and mechanical wear and tear. How good a freind is he?
/ Question on tires running down roads #5
Not R4s, but R1s, and I used my tractor on my property for 150 or so hours and never saw any wear on the tires, all the lettering on the tread bars was still like new, and I had spun on quite a few occasions in tight spots. Decided one day rather than carting fuel to the tractor, I'd run a few miles up the road (less than you are proposing) and fill it up. By the time I returned all the lettering on the treads was worn off to the point you couldn't even tell where it used to be. That is the last time mine will ever see pavement except when doing roadside maintenance or I need to use the main road to cross the creek to go to the other field, which is just a couple times a year for haying.
/ Question on tires running down roads #6
Never had r4 tires but I can say bias ply r1 tires wear very quick on the road with added weigh on the front like a grapple or bale of hay. The bucket alone doesn't seem to make them wear any quicker. The radial tires before these wore very even and weight did not seem to effect the way they wore.
With that said, you are looking at two hours on the road. Forget tires being the issue, I'd worry more about getting ran over. I'm on the road several times a week and I swear have very avoidable close calls with some impatient person at least every couple months. Get a trailer.
/ Question on tires running down roads #7
agreed, I've seen unanticipated tire wear after only a couple of miles of blacktop . I don't do it often, maybe once a year. I just bought a 24' gooseneck trailer so I can haul the tractor easily as needed.
/ Question on tires running down roads #8
Including the trailer, you'll be pushing 7-8000 lbs, I believe. So you need a tow vehicle big enough for that, and it is probably overloading a typical 7000 lb dual axle trailer. I would not try it on a landscape trailer, no way. I have a 10k trailer - 16' and it is adequate, but a bit short.
/ Question on tires running down roads #9
IF you aren't going to do it all the time, I wouldn't worry about it one bit!
SR
/ Question on tires running down roads #10
Wear with R-4s not significant. I do a lot of roading on blacktop with my L5740 between farms and have no significant wear. Longest trip I've made on blacktop is 46 miles to pick up a disc. Had no hydraulics to lift the disc so needed the tractor. R-1s are a problem although all of our larger tractors have radials which are not nearly as bad as bias ply R-1s. A L3540 base weight is 3241 no cab, no loader. Not sure about a L3240 - not in my book.
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2025 AGT Industrial MX-CRT23 (A60463)
2025 AGT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2007 JLG 2630ES ELECTRIC SCISSOR LIFT (A59823)
2007 JLG 2630ES...
