Question on tightening 200cx loader bolts?
   / Question on tightening 200cx loader bolts? #1
mx125
Toronto
JD 2320
I have the proper torques from the manual for the loader arm bolts (required checking every service). . . . But just had a question.
On the outbound side is a grease fitting with a non visible bolt through the arm. On the inbound side is the nut (24mm, I think). Although the nut is tight . . the bolt and fitting seem to pivot a few degrees clockwise/counterclockwise somewhat freely. As if the bolt/grease assembly fit in a keyed hole in the loader arm. I'm guessing this is normal and just torque against the stops? Thought I'd double check before damaging it :)
   / Question on tightening 200cx loader bolts? #2
I hope it's normal because mine is the same. I couldn't see any way to hold it from the outside end, so I came to the same conclusion as you and I just torqued them against the stops.
Thanks . . . I'm glad you found the same thing. That's all the confidernce I need!
   / Question on tightening 200cx loader bolts? #4
Yes it is normal. I've assembled a few loaders and they all do that.
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A55788)
2009 Ford F-250...
MQ Power 45 Towable Generator (RUNS & WORKS) (A50775)
MQ Power 45...
(INOP) 2021 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52705)
(INOP) 2021...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
UNUSED LANDHONOR LHR-SL2T3M CHAIN HOIST (A54757)
UNUSED LANDHONOR...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
