Question on tightening 200cx loader bolts?
   / Question on tightening 200cx loader bolts? #1
mx125
Toronto
JD 2320
I have the proper torques from the manual for the loader arm bolts (required checking every service). . . . But just had a question.
On the outbound side is a grease fitting with a non visible bolt through the arm. On the inbound side is the nut (24mm, I think). Although the nut is tight . . the bolt and fitting seem to pivot a few degrees clockwise/counterclockwise somewhat freely. As if the bolt/grease assembly fit in a keyed hole in the loader arm. I'm guessing this is normal and just torque against the stops? Thought I'd double check before damaging it :)
   / Question on tightening 200cx loader bolts? #2
I hope it's normal because mine is the same. I couldn't see any way to hold it from the outside end, so I came to the same conclusion as you and I just torqued them against the stops.
Thanks . . . I'm glad you found the same thing. That's all the confidernce I need!
   / Question on tightening 200cx loader bolts? #4
Yes it is normal. I've assembled a few loaders and they all do that.
2009 RoadTec RX500 Asphalt Milling Machine (A55787)
2009 RoadTec RX500...
2015 CATERPILLAR RM300 ROAD RECLAIMER (A52705)
2015 CATERPILLAR...
2002 8' X 30' GOOSENECK TRAILER (A54756)
2002 8' X 30'...
2022 International CV515 Ambulance, VIN # 1HTKSSWK7NH675363 (A54865)
2022 International...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
