Question on the Kubota B-2650
   / Question on the Kubota B-2650 #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
My prior tractor was a B7800 with the 3ph quarter inching valve.
When I shut the tractor off and moved the fel control lever around to
eliminate hydr pressure, both the fel and 3ph responded.
With the B2650, it seems like only the fel system pressure is relieved.
Am I doing something wrong? Is there a way to relieve the 3ph pressure, as well?
   / Question on the Kubota B-2650 #2
I do believe that lowering the TPH relieves any pressure from it.
   / Question on the Kubota B-2650 #3
Why the concern about relieving pressure?
Interesting note on the behavior of your B7800. I've had one for over 7 years now and don't recall the 3pt and FEL being tied together like you're describing. When I park I generally drop the loader bucket and then lower the 3pt (almost always have an implement attached), so maybe I'm missing this happening due to this sequence? For sure, though, it doesn't happen with the tractor running.
   / Question on the Kubota B-2650 #4
Something must have been wonky with your old tractor. Relieving pressure in the FEL circuit shouldn't de-pressure the cylinders holding up the 3 pt. Having something on the back dropping when you moved the FEL joystick would be pretty unsafe, wouldn't it?
   / Question on the Kubota B-2650 #5
Use the FEL stick to relieve the FEL and the 3 pt lever to relieve the 3 pt.....as I understand it.
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Wanco 800W Solar Integrator Trailer (A51691)
Wanco 800W Solar...
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A52576)
2016 KENWORTH T680...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
