Question on the Kubota B-2650
   / Question on the Kubota B-2650 #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
My prior tractor was a B7800 with the 3ph quarter inching valve.
When I shut the tractor off and moved the fel control lever around to
eliminate hydr pressure, both the fel and 3ph responded.
With the B2650, it seems like only the fel system pressure is relieved.
Am I doing something wrong? Is there a way to relieve the 3ph pressure, as well?
   / Question on the Kubota B-2650 #2
I do believe that lowering the TPH relieves any pressure from it.
   / Question on the Kubota B-2650 #3
Why the concern about relieving pressure?
Interesting note on the behavior of your B7800. I've had one for over 7 years now and don't recall the 3pt and FEL being tied together like you're describing. When I park I generally drop the loader bucket and then lower the 3pt (almost always have an implement attached), so maybe I'm missing this happening due to this sequence? For sure, though, it doesn't happen with the tractor running.
   / Question on the Kubota B-2650 #4
Something must have been wonky with your old tractor. Relieving pressure in the FEL circuit shouldn't de-pressure the cylinders holding up the 3 pt. Having something on the back dropping when you moved the FEL joystick would be pretty unsafe, wouldn't it?
   / Question on the Kubota B-2650 #5
Use the FEL stick to relieve the FEL and the 3 pt lever to relieve the 3 pt.....as I understand it.
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
