Question on Smoothing out rough pasture land
   / Question on Smoothing out rough pasture land #1
dannylink
Mt Sidney VA
John Deere 4720 / 1953 Farmal Super A
Question I have is how do you smooth out land where cattle have walked when wet and sunk down 6" or so making for a rough ride when driving over with tractor. I have heard that perhaps using a landscape rake would work. Any other ideas?
Thanks
   / Question on Smoothing out rough pasture land #2
I use my FEL and my bucket for this.
   / Question on Smoothing out rough pasture land #3
Smoothing it out "after" the cattle are no longer in the pasture? ..and now you are converting over to lawn?
   / Question on Smoothing out rough pasture land #4
If you don't mind killing the grass then run a disc over the tore up area and reseed. Pretty much everything will damage the grass though. First thing is to drag a chain harrow over the whole field to smooth out the really high spots and cow pies.
   / Question on Smoothing out rough pasture land #5
You should first punish those cows. I think everyone here would help out, my grill is ready!
   / Question on Smoothing out rough pasture land #6
Thanks
Disc it and then drag a log, steel pipe or something heavy to bust up the clod.
Here's the setup I use on my 6-acre hayfield.
It's an old 6.5 ft wide Towner offset disc with a bunch of tires the function as the drag. Got the disc free from a neighbor--replaced about 10 of the discs (called pans), lubed it and it's works like a charm.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
378811 (A51573)
378811 (A51573)
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
2006 BOBCAT ZHS 435 FAST TRACK EXCAVATOR (A52705)
2006 BOBCAT ZHS...
