Question on rear remotes and BH lines
/ Question on rear remotes and BH lines #1
lzicc
Platinum Member
Pittsburgh, Pa
Kubota B2650
Since my tractor has a BH, when I take the BH off, I have the 2 hydraulic lines on the rear of the tractor. Couldn't I somehow use those lines to hook up a hydraulic top link when I don't have the BH attached? Is this a stupid question? :confused2: This way I would avoid the added expense of adding a rear remote. I would use this for a box blade, rake, something that doesn't need to use the hydraulic lines.
/ Question on rear remotes and BH lines #2
Let me ask you this, when you remove the BH, do you then put a loop of hydraulic hose between the two hydraulic couplers? Or do you have a valve elsewhere?
You will still need an open center control valve mounted somewhere to restore the series flow of fluid, and control the cylinder out of its work ports.
I do loop the one into the other. I don't have to, I do it to keep the ends from getting dirt in them. I'm thinking that I may need a control valve.
/ Question on rear remotes and BH lines #4
you don't have a valve to control tnt just pressure to BH and return. could fab a control valve with a pressure relief in it. just a thought.
/ Question on rear remotes and BH lines #5
Izicc....Are you saying you have 2 hydraulic hoses hanging off the back of your tractor that you plug the 2 hoses from your BH into? Or do you have a block at the back of your tractor that the 2 hoses from your BH plug into. The reason I ask is I wonder which 2 hoses you join together so to keep "from getting dirt in them". If there are 2 hoses at the backof the tractor that you "don't have to" join together then there must be a means (lever maybe) that shuts off the flow when your BH is not installed.
/ Question on rear remotes and BH lines #6
You mention you do not have to provide the loop. This puzzles me. Unless there is another valve somewhere you turn, you would have to provide the loop to keep from deadheading the pump and to make the 3pt cylinder function. But I am not there to examine how your BH is hooked up, but I would think it is fed from the green marked hose off of the FEL valve, (the power beyond connection) and the other hose returns to the distribution block under your right foot, again to the green marked connection which is the feed to the position control valve for the 3pt. Unless another valve has been installed to "switch" the flow on and off to the backhoe somewhere, you must install the hose loop to keep from deadheading the pump and to provide flow to the 3pt control valve, and eventually on to the tank. Keep in mind I have zero hydraulic credentials, but this is what I think.
Maybe I do have to connect them. I don't remember having been told I had to. On my BX I had to, I know that. I have a L3800 with the BH77 on it. Maybe I am thinking that I don't have to connect the hoses on the BH when it is off, but I do connect them to keep the fittings clean. Let's say I do have to connect them, which you may be correct, can I still use that connection for a hydraulic top link?
I'm starting to feel like a dumb blonde anymore. My memory is not as good as it used to be. I guess it comes with age. :)
/ Question on rear remotes and BH lines #8
Well you would need a DA single control valve mounted somewhere (rops maybe?)and the proper hose connections. Can you confirm there is no other lever anywhere you have to throw to use the backhoe hydraulics, just hook up the two connections and go? And when you are done with the backhoe and remove it, you put a short length of hose between the two connections on your tractor, and your 3pt will go up and down and everything works normally correct?
/ Question on rear remotes and BH lines #10
What is the source of the flow in those lines?
If it is from the FEL valve, it needs to be connected in series.
If the hoses are from the work ports of a valve, then they can hang until you use them.
One set of hose can do one cyl. IE, T-N-T.
K0a, you are correct. I take the BH off and connect the lines. The 3 point works once the BH is off.
JJ, I'll have to check that.
/ Question on rear remotes and BH lines #12
I did exactly what you're looking to do on my BX25. Your backhoe hoses must be connected together when the hoe is off. Conceptually, you would need to insert a selective control valve between the two hoses to gain auxiliary hydraulic outlets for a TnT. I did a thread on my valve install with pic's. Will post a link in a bit. Posting from my smartphone right now.
/ Question on rear remotes and BH lines #13
Had to fire up my laptop. Anyway, here's my thread on adding an aux. valve for my hydraulic toplink using the BH connections. Of course this is for my BX so the specific connections may be different on your L3800, but I'm pretty sure you'll have the same three connections at the back of your tractor - pressure in/to the BH, power-beyond to send fluid to the next valve in series, and a tank return line for fluid flowing back to the tank when the BH is in use. Hope some of this is helpful.
http://www.tractorbynet.com/forums/kubota-owning-operating/245770-bx25-remote-valve-project.html
Thanks CHD. Nice job btw. Where did you get the valve for this? It looks like you have 2 outputs, so you can use both a hydraulic top link and tilt, is that correct?
/ Question on rear remotes and BH lines #15
The supply to the backhoe is most likely the power beyond from the loader valve. If so, you will need a remote valve with power beyond to power your 3 point lift when operating without the backhoe. In addition to the work ports which will go to your T-N-T cylinders, the remote valve will have three ports, (1) the inlet which is the power beyond line from the loader valve and (2) the power beyond port which will power the three point. Those two are the existing lines that you use for your backhoe. (3) The third port on the remote valve is a tank line. You will need to find a port on the tractor that goes to tank - the transmission case that holds the oil. There will be a tank line from your loader valve that you can tee into. The backhoe uses the power beyond from the loader and then uses the 3 point inlet as the tank line. Since you do not use the 3 point with the backhoe and keep the 3 point lever all the way down when the backhoe is on, the 3 point valve just drains its inlet to the transmission case so it is acting as a tank line for the backhoe.
If you mount your remote valve so that it can stay on with the backhoe mounted, you could use the remote valve to power the backhoe. You may want a remote valve with a detent if plan on using it for the backhoe or you could use a bungee cord to hold the valve open.
/ Question on rear remotes and BH lines #16
I sourced everything but the quick connects from Surplus Center. I find their website fairly easy to navigate and understand for hydraulic stuff, and the prices are good. Not sure what details I put in my thread on specific supplies. This is the valve I ordered, but you need to make sure whatever valve you use is rated for at least the amount of hydraulic flow your machine puts out, not total flow including power steering, but GPM used for hydraulic implements - FEL, BH, etc. Also, make sure it has a power-beyond port on it, since you want it to sent pressure downstream to whatever is next in your hydraulic system, e.g., 3PH.
9-7862 2 SPOOL 8 GPM PRINCE MB21BB5C1 DA VA 151.95
Link
https://www.surpluscenter.com/Hydra...OL-8-GPM-PRINCE-MB21BB5C1-DA-VALVE-9-7862.axd
You need to figure out what each hose that is connected to your BH (when on) does. Dealer service or parts department might help, but sometimes you can tell from the parts diagram since it often labels these parts with notations like PB, or T for Power-beyond/ Tank Return. etc. Or maybe someone here with the same tractor can provide that information. Once you know what hoes does what, you can figure out how to hook up the hoses to the correct ports on the valve. For that you'll need hoses of the appropriate length and the correct fittings. When/if you get that far, I'm sure you can get help here or in the Hydraulics forum.
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
KL480 Ventrac tiller
2021 KMC 7406 (A64126)
