Question on Phosphoric acid rust converters
/ Question on Phosphoric acid rust converters #1
nfernandez
Bronze Member
Byron Center, MI
John Deere 2210
I just bought a used 60" snowblower attachment that was kept outside by the previous owner. There is a fair amount of rust on it, but also some dull old paint. For those that have used phosphoric acid, do you just apply it to the entire surface to make sure you get all the rust spots? Then paint a primer over that? I'm not sure if you put phosphoric acid over old paint if that would cause any issues, but I don't want to miss any small rust spots. Thoughts?
/ Question on Phosphoric acid rust converters #2
I use Gempler's stuff. Just paint it on the entire surface, clean it off with a rag or paper towel after the recommended time, primer then top coat. Seems to work OK for me.
/ Question on Phosphoric acid rust converters #3
I'd avoid getting it on good paint (paint that is well adhered ...)
On the rusted areas, remove any (heavier) rust (wire wheel, flap disc, etc.) as much as possible and then spot treat the specific areas.
/ Question on Phosphoric acid rust converters #4
Yes. I've got it on paint and no ill effects. It seems to soften it but then I paint right over it.. Fine for my trailer/implements. It's not a show car.
/ Question on Phosphoric acid rust converters #5
You should sand the old paint and feather the edges prior to putting on new paint so I would sand first then acid treat. The acid I have used before (WEDAC) does nothing to the paint, just bare metal ( rust ) is affected.
2016 Ram 5500 Flat Bed (A63688)
2016 Ram 5500 Flat...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
John Deere 825I (A64127)
John Deere 825I...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
AGI Westfield WRX 8-61 (A64126)
AGI Westfield WRX...
