Question on MF 135 pto
   / Question on MF 135 pto #1
Woodcanoeguy
Pacific NW, SW Washington
JD 830 FEL, JD 820 mint, MF 35, TO35
I just got a new to me MF 135 that has the independent PTO.....the first Ferguson or MF that I have had ( over 8 so far) that has it. My first question is can I just feather it slowly into gear with an implement attached? Second question is regarding the pto brake ....(when lever is pushed forward) ....it does not seem to stop ( or even slow down) the PTO shaft.....any adjustments I can make there? Other than this the tractor is really in great condition and runs well.....gas engine.
Thanks in advance for you
   / Question on MF 135 pto #2
You have the IPTO model. Again two models, with and without multipower transmission. If the rest of the hydraulic system is fine you have to lift the hydraulic cover and inspect the clutch unit and regulating/modulating valve. I personally have never worked on these models but that is what i know of them. Have some info in a manual somewhere, can look if you want. We have 19 of the previous 135's and 3 35X on the farm.
Lever forward - disengage
lever backwards - engage
Thanks for your help Tanqwa.....will give the Massey dealer a call. They have been around a while so will know about 135's
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
