Question on imatch and drive shaft for 2305
   / Question on imatch and drive shaft for 2305 #1
Henri88
Platinum Member
Northern N.B.
2008 JD 2305, 1000hrs
I have a 2305 with a 48'' frontier tiller, here my question. If I install an imatch do I have to replace the drive shaft? Will the extra distance from the pto to the tiller make it to short? My drive shaft is presently as long as it can be without being to long. I don't know the extra distance the imatch will give me.
   / Question on imatch and drive shaft for 2305 #2
I Match will add very close to 4 1/8 inches to the attachment length. This is measuring from pin to hook on the I Match unit.
   / Question on imatch and drive shaft for 2305 #3
How much overlap do u have with the driveline now ?
4'' It should be good. I will take measurement but I'm quite sure I have long enough to be safe. Thanks jenkinsph.:)
Willl, I will get the measurement and get back to you.
Well, just got back from my garage. Took some measurement and it doesn't look good. :(My jd is already setup with the snowblower and my tiller is put away for the winter, so I had to take the measurement without having it install and it looks like I would have approx. 3.5'' overlap at the farthest point ''attachment bar horizontal'' that includes the extra 4''. I don't think 3'' overlap would be a safe distance to operate the tiller. I don't have a choice, tomorrow I will take the time to install the tiller and remeasure it. Any idea what would be a safe overlap? Thanks
Thank you Kennyd. Sure is cheaper than buying a new drive shaft. Didn't no it existed.
IH 1566 Tractor (A50514)
IH 1566 Tractor...
3in Poly Pipe (A49461)
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
Toro Workman Cart (A50322)
Toro Workman Cart...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
