Question on hydraulic pto pump for a Tc33 new holland tractor ..
   / Question on hydraulic pto pump for a Tc33 new holland tractor .. #1
Swamp Rooster
New Holland TC33 2003
I am looking to power a log loader on a trailer . My tractor does not have ports in the rear and I thought I would us a PTO hydraulic pump to run it . My tractor is a Tc33 new holland. The ports are expensive and also this could help me keep the oil from the loader seperate from my tractor . Any advice would be appreciated..
   / Question on hydraulic pto pump for a Tc33 new holland tractor .. #2
The PTO pump system will also need a reservoir unless the trailer has one already. If it's made to be run off a tractor it probably doesn't. It might not even have a relief valve.
Mounting a set of valves will cost you less than the PTO pump etc and you'll be able to use them for other stuff. Also you can get one valve with a detent so you don't need to bungie cord the handle.
   / Question on hydraulic pto pump for a Tc33 new holland tractor .. #3
Yep, a PTO pump is a whole new set of things that will need to be dealt with. Probably not the easiest or simplest solution.
   / Question on hydraulic pto pump for a Tc33 new holland tractor .. #4
my pto pump has a 25 gallon reservoir tank. I didnt need a cooling fan as i use it in winter time only. for summer use you may need a cooler unit. The fluids get hot. Not cheap by any means. heres mine powerpack 1.jpg. i got mine from Hydraulic Power Unit : Quick Attach Attachments, Inc.
good luck
   / Question on hydraulic pto pump for a Tc33 new holland tractor .. #5
OP needs to think of this like running a log splitter off the tractor. Intermixing the hydraulics isn’t an issue.
The other thing the OP could do was undo the curl QDs for the loader. Just have some hoses made for the trailer with the right length and matching QDs. This would be a fairly simple option.
   / Question on hydraulic pto pump for a Tc33 new holland tractor .. #7
That will work. It may be more GPM than the original which would make the cylinders move faster but of course you can run the tractor engine at a slower speed. You'll need to make a torque arm to keep the pump from rotating but that's pretty easy. The 8 gallon tank should be large enough.
   / Question on hydraulic pto pump for a Tc33 new holland tractor .. #8
Swamp
Any idea on what the flow was with the Honda engine? I would guess around 4 - 5 GPM. Based on that the 16 GPM PTO pump might be to big even with your tractor idled down
Fast moving cylinder on log loader might not be a desirable feature
Thanks all , been working like a fool . Got it all set up and working but have new question to ask . I will start a new thread and try and get pics up. Thank you all again .
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
ALLIANCE 480/80R42 LOT IDENTIFIER 121 (A53084)
ALLIANCE 480/80R42...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53472)
2020 Westfield MKX...
