Question on DK45SE HST 50-hour Service
   / Question on DK45SE HST 50-hour Service #11
For changing filters I run one side of my DK35 up on two 6" x 8" blocks to tilt the tractor, first on the right for the hydraulic filter, then the left for the HST filter. No oil comes out after the initial bit spilled from the filters.
I changed my hydraulic oil after the initial 53 hours. However, on my dealer's recommendation I did the next hydraulic oil change at 709 hours (i.e. about 650 hrs after the initial change). The manual recommends a 400 hr interval for hydraulic oil changes but my dealer said around 800 hrs was more appropriate for my use. Later he said perhaps 600 hrs. So I did it when convenient (in the summer) at a 650 hr interval. The used oil did not look different than the new oil. This recommendation may be meant only for my relatively light usage conditions. I don't have a backhoe or other hydraulic equipment and don't have a lot of continuous heavy dragging work. So I'm not recommending my oil change interval is appropriate for others.
I found metal bits on the magnetic drain plug during both oil changes. I recall several on the first change and one or two on the second.
Addition to original post since it has not yet been mentioned......
You need a good filter wrench for the first oil change. The filters are very tight. A strap wrench that fits on a 1/2" ratchet worked for me but I twisted it like a pretzel helping my neighbour with his CK's 50 hour service. I got a Channel Lock 12" filter pliers:
https://www.channellock.com/212-Oil-Filter-PVC-Plier.aspx
and highly recommend them. They fit all the filters on my DK35 from the small diameter HST to large diameter hydraulic.
   / Question on DK45SE HST 50-hour Service #12
Agree. The factory paints over the filter base so the filters are "glued" on. You'll need the heaviest truck filter wrench you can find or cut the paint at the filter base with a razor blade.
I changed the hydraulic fluid at 50 hours and found 5-6 metal slivers on the magnetic drain plug as well. Probably from shifting through the HST range. Also did the front axle. Since you have to buy three 5 gallon pails of UTF you'll have enough left over to do the front axle.
The manual is confusing/not up to date. For instance, I have a sight glass on the front axle that is not mentioned. I don't have the grease nipples they show on the hydraulic steering cylinder.
   / Question on DK45SE HST 50-hour Service #13
I just changed the hydraulic filter in my DS3510 last weekend. It took every ounce of strength in my hands to get that thing off in that tight spot behind the tire. Using a junk wrench didn't help, the four letter words I was spewing didn't either. There were also plenty of metal flecks in the fluid that poured out of the filter.
   / Question on DK45SE HST 50-hour Service #14
The manual is confusing concerning the 50 hour check and oil/filter changing. I changed all oils and filters as they are relatively inexpensive maintenance insurance.
The hydraulic filter was a ridiculous, very trying event spread out over several attempts and so many weeks. Due to everything I had read on TBN about this filter, I had purchased two high quality strap wrenches, of different types and made up cheater bars/pipes. None of these worked as the strap would eventually slip on one wrench and the other had just enough play in it to be of little use. I also tried to find a metal filter "socket" that I could get a ratchet and breaker bar onto, to no avail. This search involved the typical local auto parts places and a pro tool supplier that delivers by truck and an Internet search. I was trying my best not to damage the filter enough to the point I would have to cut the filter off, 35 miles from home with no A.C. power and then no ability to move the tractor under its own power. I finally ordered a Crescent CW15 15-Inch Chain Wrench, which gripped well but I did not have enough leverage. I finally called a much younger, much larger, much stronger friend who is a certified, ex-military mechanic. He used the chain wrench and all of his strength and it finally broke loose after his third and probably final attempt. I believe he may also have used a cheater pipe on the end on the wrench handle, but do not recall for sure; I was just so happy the darn filter came off.
By the way, my filters did not appear to be painted on. And to make sure this should not be an issue, I took a razor blade and cut around the filter gasket area before trying to remove it.
I also test my oils at Blackstone Labs. The hydraulic fluid came back with a very clean report, even though the magnetic plugs had a lot of shaving on them- coated, actually and piled high like a mountain. The engine oil came back with very high levels of lead, ~ 700% higher than normal indicating a potential bearing problem. My tractor is running fine and has since new. I just changed the engine oil and filter at 100 hours and will send in another sample next week.
   / Question on DK45SE HST 50-hour Service #15
It is crazy how tight the filters are. As mentioned earlier, I twisted the shaft on my 1/2" ratchet mounted strap wrench trying to remove my neighbour's CK hydraulic filter although it did work for my DK filters a few years earlier.
My dealer has complained to Kioti about the tight filters but nothing has happened. When I told him about helping my neighbour remove the factory filters he said that his dealership should loosen and re-tighten the filters as part of the dealer prep. I'll mention it again to see if they will start doing that.
   / Question on DK45SE HST 50-hour Service #16
I got mine loose by drilling a hole through it and driving a piece of 5/8 all thread about 3 foot long through it and grunting. If the dealer uses my method, well, I don't think it is going to work out so well.:D
   / Question on DK45SE HST 50-hour Service #17
Agreed! But it does not seem like good customer service to deliver the tractors with such a problem. My dealer did say they at times use your method of driving a bar through the filter when removing a factory filter. If they loosened and reinstalled the filter before delivery it would save trouble for unsuspecting customers. I was very grateful for being forewarned about it by postings on TBN. And my neighbour was no doubt happy I let him know for his CK's first service.
If the dealer wrecked and replaced a filter with a pre-delivery reinstall perhaps they could charge it to warranty. That might make Kioti change how they install them at the factory.
I do recommend the Channellock filter pliers. It was able to remove my neighbour's filter that broke my strap wrench and is handy for future filter changes and other jobs.
   / Question on DK45SE HST 50-hour Service #18
That and fix the throttle handle being to hard to move..
   / Question on DK45SE HST 50-hour Service #19
I broke 2 metal strap filter wrenches before I listened to the advice that has been repeated in here ... over and over again :) My 3rd filter wrench was a chain wrench. It was still quite a workout - but - it worked! I wasted the better part of 2 days getting that stupid filter off.
   / Question on DK45SE HST 50-hour Service #20
I bought a chain wrench, AFTER I got the filter off with the drill a hole and pound in the 5/8 all thread for a lever thing. I figured I should have had one all along. It would have saved me a lot of time and grief.
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2016 Chevrolet Tahoe SUV (A55973)
2016 Chevrolet...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2015 FREIGHTLINER...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
