Question on Cultipacker For Sale
   / Question on Cultipacker For Sale #11
That is exactly like mine and it works great .
How heavy would you estimate it to be? Does yours have the wooden hitch? I was wondering if that was original or not.
   / Question on Cultipacker For Sale #13
Big Barn, do they have the same intended uses?
Not really. A cultipacker (which would have tines) would be for secondary tillage (after plowing for instance) and seedbed preparation. The tines would provide a bit of leveling action as well as tilling the soil. Rollers on their own tend to exaggerate high and low spots.
The double roller/packer similar to yours we would have coupled in tandem BEHIND a cultipacker which would be in turn hitched to a ten or twelve foot Howard rotovator. Sorry no pics. That was a lifetime ago.
Your implement is great for firming the soil for final seedbed prep or breaking clods in certain soil types. It could even be pulled behind a disc harrow.
It might not eliminate tire tracks in certain soil types if used by itself....if that is an issue.
   / Question on Cultipacker For Sale #14
Nice find. But just for the record that isn’t a cultipacker. It’s just a double row /roll packer.
A Cultipacker(John Deere) or the more popular Pulvimucher (Brillion) have a row or two of tines in the middle.
I get your point but in KY what is in the picture is called a cultipacker. The tines would have been hard on the mules that pulled it. :) The oil/grease cups were common on horse drawn equipment 100 years ago. The wooden block bearings would become grease/oil soaked and work harden the blocks. Mules top speed was well under 15 MPH. :)
Below on ebay would be my dream cultipacker.
3 pt. Brillion 6 ft. Double Cultipacker (FREE 1 MILE DELIVERY FROM KENTUCKY) | eBay
   / Question on Cultipacker For Sale #15
Gale that eBay ad is for a used item which is incorrectly labelled.
Brillion did not make anything called a Cultipacker which is a John Deere trademark.
Brillion’s Pulvimulcher and JD’s Cultipacker were similar implements with ridged rollers and tines.
Over time simple ridged roller implements such as the ad depicts and the OP has were generically labelled cultipacker. Sort of a CAT scenario referring to all tracked power sources as such.
Even Wikipedia is incorrect in its description. I realize this is a mere technicality that happens to many items and phrases over time. I suppose I am just doing an excellent job of showing my age. Lol.
   / Question on Cultipacker For Sale #16
Kind of like drywall and sheetrock, skilsaw and circular saws perhaps.
I never knew the naming history so thanks for that info.
I have decided I "need" a Brillion Pulvimulcher. :)
   / Question on Cultipacker For Sale #17
My apologies to all including the OP for the unnecessary history lesson.
I realize of course that the term CULTIPACKER will continue to be used when referring to most implements close to matching its original configuration. Hats off to John Deere for a brilliant design and great marketing.
   / Question on Cultipacker For Sale #18
Interesting... Around here what Big Barn is describing has always been called a cultimulcher, front packer, typically 2 rows of C-tines followed by a rear packer. What the OP shows and is looking for like so many other areas is called a cultipacker regardless of manufacture and # of packers. Most common and maybe only manufacture of cultimulchers that I have ever seen are Brillion and John Deere.
   / Question on Cultipacker For Sale #19
The term cultipacker appeared in English around 1914 and probably originated as a brand name of the C.G. Dunham Company of Berea, Ohio, which advertised "Culti-Packer" models starting around that time.
   / Question on Cultipacker For Sale #20
Farming in California in the 1950's and 60's we used a somewhat similar tool we called simply "the roller" both for seedbed preparation and to firm up after planting row crops.
It had alternate wheels and toothed disks. The wheels were cast iron, with a flat surface maybe 2" wide, but with a thin raised rim in the center, projecting from the flat rim maybe 1 1/2." Those ran on a steel axle, but I think were not very tight on the axle so they could move a bit. Between each pair of them was a narrow, maybe 3/8" in thick, disk with the outer edge toothed, maybe an inch deep. They ran on the hub of the adjacent rollers, but with the center hole much larger so the floated freely.
Ours was three sections, the center maybe 8', with a pair of 4' ones on either side drawn by outriggers on the center unit. Since it was twice as wide as the planter and ran significantly faster, using it was a perfect task for a boy after school, rolling in what had been planted that day.
I've never seen one since I left the farm in the mid-60's and have no idea who made them. I don' think was a major brand, maybe locally produced.
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2013 HYUNDAI Veloster Hatchback (A56859)
2013 HYUNDAI...
2853 (A58376)
2853 (A58376)
2232 (A58376)
2232 (A58376)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
