Question on a branch circuit
/ Question on a branch circuit #21
There is one loophole to the general rule that the wire has to be the same size throughout: the wire between an outlet and a device can be smaller.
Install an outlet box. Put a plug cord on the lights and plug it into the outlet.
Great idea, those led's don't pull much anyway.
/ Question on a branch circuit #22
Yes, but now the receptacle has be GFCI (as per 210.8 (B) 8).
The receptacle does not need to be GFCI if it is NOT 'readily accessible'. As in mounted 6 feet or more above grade. ( On the ceiling? ).
I am not aware of that. Where are you getting that from?
As per 2017 NEC, garages need GFCI receptacles whether they are attached as part of a dwelling unit (see Code 210.8 (A)(2)); or not (see Code 210.8 (B)(8).
In fact, the fine print notes for 210.8(A)(2) says "There are no exceptions. All...receptacles installed in garages must provide GFCI protection regardless of where the receptacle is located..
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
