RBManufacturing
- Joined
- Oct 31, 2000
- Messages
- 286
- Location
- Riverside, MIssouri
- Tractor
- Ford 8N / Kubota B 6200. Kubota B 7100. Modified wards lawn tractor. Souped up.
I bought a 1976 postal jeep for new toy. Plan to use around
farm, as well as fun. Has original 232 c.i. 6 cyl. automatic.
Sandblasted entire body and re-painted bright red with small
yellow flames on hood. Undercoated, added passenger seat
up front, and two small bench seats in rear. Tuned up. New
carb, new electric fuel pump, new coil, electronic ignition
module, new plugs, wires, rotor,fuel filter, and much more.
Ran fine for a few weeks. Now, sometimes it starts well,
and runs 5-10 minutes then starts loosing power, missing
out, and dies. At first it started right back. Now it usually
will not start, and when it does, it misses, and dies again.
All valves appear to be opening and closing as they should.
I removed valve cover to watch. HELP! Also, if I decide to
ditch the 6 cyl. and put in a 302 c.i. v-8 from a ford, will I
have to put in a voltage regulator etc. or will the electronic
ignition module work for the v-8 like it did for the 6 cyl.???
It appears that the voltage is regulated by the iignition
module now. Any major problems you see in the switch?
Any help appreciated! Rick /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
