Question for welders/fabricators.
/ Question for welders/fabricators.
When I worked for FNH, I got sick of replacing clutches on 1710's and 1715's with front end loaders and 4wd. Average lifespan was about 25 hours when used hard . On the other hand, I had it down to about an hour and a half if it had a loader on it to RandR. Split it and you'd see little cords of string that looked like a rat's nest. It was part of the clutch material that would disintergrate. If you cut a hole, find a busing to weld in it that matches the diameter of your hole.
Why would the clutches wear out so fast? Clutch material or crappy design?
/ Question for welders/fabricators. #22
Both and operator idiocy. Riding the clutch. The best solution was the 1720 hydrostat. Those clutches were tiny. You got a lot if pressure and abuse. People would reverse w/o stopping, would ride the clutch, would slip the clutch while loaded by changing gears etc. Torque converters and hydrostats are yhe best way to go with f.e. loaders unless the tractor is 80hp or over.
Hopefully I can make mine last a while. I would hate to split the tractor. Seems dangerous as **** if you dont know what your doing.
/ Question for welders/fabricators. #24
No. It's easy to split not too dangerous, just time consuming. Two trolley jacks and some wood blocks. Front axle shoud have a wood wedge driven on each side under the pivot stops before splitting so it doesn't flop when pulled apart. I've pulled the engine out of them in the field bare handed with the help of another guy and lifted it manually onto the back of a truck.
You would think they would make the clutch more accesible or use a torque converter like you said.
Do you by any chance know the height of the loader stands? I need to make loader stands to remove FEL.
/ Question for welders/fabricators. #27
Another option maybe to hang it. On my old farmall m I hung my loader off of rafters (2"×4") with 2in ratchet straps just fine.
/ Question for welders/fabricators. #28
/ Question for welders/fabricators. #29
Only motorcycles have easy-access clutches! Otherwise, cars, trucks, and tractors require some major disassembly (some cars require removing the engine!) At least you don't need a lift to change a tractor clutch, unlike most other four-wheeled vehicles; I hope to never change it on mine, but it appears that it would be an easy one-day job, with the biggest PITA being the zillion hoses that would need to be disconnected.
/ Question for welders/fabricators. #30
Except for BMW motorcycles, their built just like a tractor or at least they were up untill a few years ago when they finally got some smarts.
/ Question for welders/fabricators. #31
Valmet had tractors that you could change the clutch without splitting it. The last ones I saw that had that design had that I knew of that claimed the feature had so much clap trap that it was only a theoretical possibility and by the time you got to everything, you were better off just going ahead and splitting the tractor.
378909 (A61166)
378909 (A61166)
2010 Deere 318D (A60462)
2010 Deere 318D...
2019 Chevrolet Express 2500 Cargo Van (A61568)
2019 Chevrolet...
3015 (A56857)
3015 (A56857)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 Troy-Bilt 18in. Push Mower (A60352)
2016 Troy-Bilt...
