Question for other 3005 / 790 owners.
   / Question for other 3005 / 790 owners. #11
I have to say that even though the PowrReverser trans is a great piece and the ability to change direction without any clutch input or shift gears on the go is a nice option, I think I have come to the conclusion that I wish I had bought the 3005 instead. My main reason for buying the 3320 was the loader capacity of the 300cx. I have now come to realize I really don't need the extra capacity of this loader and that the 300 on the 3005 would have been a more than adequate loader. In terms of the transmission, I actually prefer just a regular gear mesh transmission compared to the Reverser. I grew up on gear mesh transmissions and to me the extra shifting is not a hindrance, I find it fun and it just gives me another reason to enjoy my machine.
But, I won't give up the 3320. It's light years ahead of what I used to cut grass with and the fact that it just runs properly is more than enough incentive for me to be very happy with it.:cool:
....the only time I've driven a hydro I put it through a fence....
As is often said on this forum -
WE WANT PICTURES!!
:D
   / Question for other 3005 / 790 owners. #13
The transmission isn't syncronized in any gear. If I don't let mine stop or almost stop I will grind the gears. I haven't found any way around that. If anyone else knows how to shift and not grind without stopping please clue me in.
Nearly all the old farm tractors I worked as a kid; were collar shifts. You gotta stop and throttle back. And if you don't want to pull the throttle all the way back down to idle - work the clutch - several times; to stop the "overrun" in the transmission.
But, IMO; having the rpm's up around 2,000 is a good way to smooth the edges off the clusters. I think I'd be around 1,500 at the most.
AKfish
   / Question for other 3005 / 790 owners. #14
So will catching the right foot on the shift lever while dismounting, transmission in neutral and the tractor running.:(
Nostalgic? I wanted a tried and true sliding gear transmission. Don't have anything against hydro transmissions, but the first thing I learned to drive was my granddad's 60 year old 8n. He bought it new in 48 and still uses it every week. I expect my 790's sliding gear transmission will be going strong in 60 years also.
   / Question for other 3005 / 790 owners. #15
As long as JD keeps selling this old school technology, I will buy them. It is proven and bullet-proof. If I did not have access to the 790 or 990, I guess I would probably go orange again.
   / Question for other 3005 / 790 owners. #16
I agree that the 790 must be stopped in order to change gears. But, the tractor will start from a dead stop in 4H. If I needed a tractor for industrial back-and-forth excavating, I'd want a syncro tranny. Otherwise, in my fields, the simpler the better.
   / Question for other 3005 / 790 owners. #17
Yup.. good point - Deere had it right a few years ago with the 70 series of CUT's.
Those models; 870-1070 had the bulletproof 9x3 tranny with SYCHROMESH gears (optional in 2WD and standard with 4WD)! A REAL thing of beauty! I don't recall if the 670-770 had the 9x3, though. They may have had the 8x2 transmission with optional synchromesh.
Some marketing, pencil-pusher must have stuck his finger in the air... before that decision!
AKfish
23'x22' Double Garage Metal Shed (A53316)
23'x22' Double...
1999 WABASH 48X102 FLATBED TRAILER (A55745)
1999 WABASH 48X102...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2016 FREIGHTLINER...
40ft High Cube Shipping Container (A54865)
40ft High Cube...
2022 Kubota L2501D Compact Tractor (RIDE AND DRIVE) (A50775)
2022 Kubota L2501D...
