jeconn, thanks for the update.
If the parts book I have is reasonably up to date, then your FIL's
L3000 has the original "Jerky" valve that has caused so much trouble in the
L3400/
L2800. And it sounds like, although not butter smooth it much better than your
L3400.
I'm not surprised adjusting the lowering valve made no difference.
As previously stated, I'm not an engineer, nor a mechanic but from what I've gathered, the lowering valve is not much more than an adjustable check valve.
When the position control lever is raised, the hydraulic fluid rushes through the lowering valve and into the 3 point cylinder. If the lowering valve is closed the check feature blocks the flow and the hitch will not lower when the lever is moved down but will still allow the hitch to be raised further if it's not yet at it highest point.
Adjusting the lowering valve does not affect it check function as to allowing fluid to enter the cylinder but it does affect how fast fluid can leave.
Still noting that I could be wrong about this, the key difference between the lowering speed valve in the
L3000 and the
L3400 is a spring. I believe that this spring tempers the burst of fluid from the lesser quality position control valves to allow smoother 1/4 inch performance in the
L3000. With the better quality position control valves, I believe it allows feather smooth performance.
In summery, what we've seen is an
L3000 with 1/4 acceptable performance from the "jerky" valve and an advance lowering speed valve. We've seen lots of
L3400/
L2800's with the Grand L valve produce similar 1/4 inch performance with a basic lowering speed valve... and two reports of Grand
L3010's with both the Grand L valve and advanced lowing speed valve produce smooth results.
Both models lowering speed valves use the same "valve body" and I strongly suspect they are interchangeable. I'm at a point where I'm convinced, unless someone more knowledgeable can contradict my hypothesis, that replacing the lowing speed valve (if possible) will result in the same level of performance improvement as replacing the position control valve. Replacing both valves will result in "Grand" performance.
If compatible, the lowing speed valve is a $90 part and would be easier to change than a tire. Two exposed bolts, pull, replace and re-bolt. Thats it. I think.
And if my conspiracy theory is correct, Kubota DOES NOT want you to know this.
