Question for Kioti Dealers
   / Question for Kioti Dealers #11
That is a over running clutch...the more you hear it the more you wear it out.
Pull the lever out and your good.
Thanks Rick, I have been saying that for years now and don't think anyone trusted me...
I am sure they trust you. :D
3.5yrs (350+ hrs) of snow blowing and I have never used the clutch to disengage the PTO, only to engage it.
   / Question for Kioti Dealers #12
Well, I am sorry to say I change gears in the viper without clutch all the time, I do use the clutch to start moving, guess its the same, engage pto and use clutch to start and drop rpm and disengage pto to stop, never knew this, thanks, my rattle and noise will now be a piece of the past
   / Question for Kioti Dealers #13
I was reading all of this and it got me to thinking :confused:
I have always pushed the clutch in before releasing the PTO.
I can't imagine what would/will happen by reducing the RPM to stop the PHD.
With the mower decks, I don't see a problem.
If Rick say's that's the way it's supposed to be done, I'm willing to give it a shot.
Tom
   / Question for Kioti Dealers #14
Would you shift gears in your car or truck without using the clutch?
I think you will answer the question that way.
Why else would the factory install a clutch?
Also disengaging without clutching will probably lead to rounded gear teeth with time, especially since PTO gearing are not syncro gears.
Remember the old cars?
Sure, I remember the first car I owned was a 51 Chevy with a three speed manual on the column. I drove it quite a bit it of the time using timing and letting off on the accelerator to release any torque on tranny and shifting from second to third or even first to second while rolling and without the clutch. Those old trannies had synchros in second and third gear but you could not shift into first or reverse while rolling. Of course not, and you could not shift to 1st while idling and parked in neutral.Get that old car rolling and shifting to 2nd or third w/o the clutch was as smoothly accomplished as if I had depressed the clutch. Same goes for shifting out of pto after throttling down. Thanks DMace for the memories. That old car had about 200,000 miles on it when I got rid of it while it still was running. The original owner showed me how to shift w/o clutching. Those were the days.
rimshot
that's exactly why i thought it best to use the clutch the same way on the pto (on/off) as i did on range changes (hi/low)......
HOWEVER..... according to the info.....
Range change clutch = YES always
PTO - ON = clutch = YES
PTO - OFF = Clutch = NO !
Dmace
it's not that we don't trust you, but it does carry a little more weight coming from a World Famous Dealer of the Highest Integrity who sells, services and deals with the warranty issues on these units....
Thanks Derek, and Thanks again Rick for all of your insight and help on this forum.
Jim
Yellow Posts (A55973)
2019 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP3KFA58619, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2019 Ford F-150...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
2006 Wells Cargo 16ft T/A Enclosed Cargo Trailer (A55973)
2006 Wells Cargo...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
Carolina 30-Ton Capacity Shop Press w/Pittsburg 20-Ton Jack, Model CP100, S/N 04020 (A59076)
Carolina 30-Ton...
