Question for BX2750D snowblower owners
/ Question for BX2750D snowblower owners #1
Rfisher7381
South West Michigan
Kubota BX2360
Just installed my new blower (purchased late spring 2011) on a BX2360 today. When I engage the PTO I hear a fair amount of noise from the area by the chain reducer. Not grinding or squealing. More of a moderate howling. From the front of the unit It is much less noticeable so I don't think it is the second stage auger rubbing on the housing. I took the guard off and checked things over. Nothing appears wrong. The chain seemed very tight so I did loosen it slightly but that didn't make any difference. Can anyone who has this unit comment on how yours sounds? Thanks
/ Question for BX2750D snowblower owners #2
My bx2750 makes the same noise I beleive it is caused by the fan moving air at a high rate. Kinda sounds like a whirling noise
Thanks for the feedback. Ran it again and it definitely makes a howling noise but it's probably just all the moving parts, plus the second stage wheel is moving a lot of air.
One other question. When lowering the blower to the ground do you advance the lever to the float position?
/ Question for BX2750D snowblower owners #5
Yes. Life is much simpler that way. If you miss float you will raise the front of the tractor.
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
2020 CATER PILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATER PILLAR...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
