Question for all the specialist in Kioti.
   / Question for all the specialist in Kioti. #1
Larno
Trois-Rivieres Quebec, Canada
Kioti CK 4010 SECH 2017
I have a CK20HST with backhoe KB2465.
Is my question with what serf the two holes located on the top?
My dealer did not know the answer. Me I think quite simply that they will be used for future thumps.
Which are your opignons PLEASE.
Regards
   / Question for all the specialist in Kioti. #2
I'm going to guess they're there to help in the manufacturing process. Looks like if you hung that piece by a hook in that hole, it'd hang just about straight up and down.
   / Question for all the specialist in Kioti. #3
That I one nice backhoe. Alot nicer than mine on the my ck30. The holes seem too big to be for lights. It could be that the backhoe is use on another type of machine other than kioti and the piston/ram is mounted on at that location rather then the current configuration. I put a thumb on mine and no i don't think it has anything to do with that. If you go with a thumb, do a fixed one, not a hydo one for less problems.
Aloha
joe
   / Question for all the specialist in Kioti. #4
There is no reinforcment around the hole so my guess is a tooling hole for manufacture,
   / Question for all the specialist in Kioti. #5
I too have no clue..... but I like how the backhoe boom lock is now. I don't like the hole on my KB2375, the holes don't quite line up and sometimes it is a pain putting in the pin. Very nice setup though Larno!
   / Question for all the specialist in Kioti. #6
Bonsoir, Michel.
Those holes are there to encourage your participation on TBN where you will get all manner of opinions and even occasionally helpful ones. This is not one of the helpful ones unfortunately.
By the way, it looks like you have a different version of the KL120B loader than I've seen before. There seems to be a tube cross brace on the torque tube but it is closed over with a cap rather than open like on the KL120Bs that I have seen before.
   / Question for all the specialist in Kioti. #7
Hey Michel. Where did you get your Clinometer from Bombardier ? I want one :D Thanks. Paul in Newfoundland
   / Question for all the specialist in Kioti. #8
Hey Larno do you have relatives in CT?
Check this out
The Newtown Bee
:) I think she is here legally
   / Question for all the specialist in Kioti. #9
I"m not sure why they are there, but if you ever need to lift the dipper stick off the boom, you can put a pin in there and attach a chain/strap to lift it with...
   / Question for all the specialist in Kioti. #10
Bonsoir, Michel.
Come'on Island, We didn't get to chech out his authenticity certificate yet, He may be faking that bad punctuation...
Jake
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
Safety Basket (A50121)
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2008 Ford E-350 Versalift Vantel29N 29FT Bucket Van (A50323)
2008 Ford E-350...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
