MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,680
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I've spoken with about 10 different Massey dealerships, & I also called AGCO directly ... each place has said not to change the tire size, because the rear and front tire sizes are supposed to work together with a Certain Ratio in mind.
However, none of them could tell me if there was any room in that ratio for adjustment, however small, to go up or down a tire size.
None said that there was not any room for adjustment, but they all said they did not know.
I I know some of you have mentioned to just not use the 4 wheel drive, but that would not work at all, as I use the front drive wheels all the time for doing loader work. Just would not be practical to not use 4 wheel drive
I still say to figure out what the ratios are for the 2 different OEM sets of tires and confirm that they do indeed use the same gearing on the tractor for those 2 ratios. Anything between those 2 different ratios should be fine.
Good luck.
