Question about using box blade to cut ditch
   / Question about using box blade to cut ditch #1
RRX
Mt Juliet, TN
Kubota L3200 HST
In the ETA video, the guy is tilting the box blade by shortening or lengthening one of the two lower links. My tractor has the fixed length lower links. Is there something I'm missing or is there a special link out there?
   / Question about using box blade to cut ditch #2
RRX:
What tractor do you have? I'm certainly no expert, but I think most tractors have at least one adjustable lower link -- mine is on the right side.
   / Question about using box blade to cut ditch #3
Some also have to be disconnected from the draft arm to change the length, top half of the lift link is threaded into the lower yoke.
   / Question about using box blade to cut ditch #4
I also watched the video and while I'm still awaitingreceipt of my BB, I wondered if there would ever be any benefit to having both lower links adjustable?
For instance, if both had turnbuckles, you could shorten one and lengthen the other to really torque tthe blade angle angle and I wondered if that could be useful for ditching or cutting into a bank....
Any thoughts?
Rad1956 said:
RRX:
I won't have it until later this week, but it is a Kubota L3200.
   / Question about using box blade to cut ditch #6
It seems to me that the larger the tractor, the more likely both links are adjustable. Probably more to help attach heavy implements than to tilt an implement farther.
Bruce
   / Question about using box blade to cut ditch #7
It is handy to be able to tilt the box blade -- I tilt mine to get the crown I need on our access drive which is very steep.
   / Question about using box blade to cut ditch #8
Any thoughts?
It certainly would not hurt anything and you would get alot more angle. Could be useful in some special situations.
   / Question about using box blade to cut ditch #9
I also tilt my BB when I'm grading, although for more agressive ditching I use a rear blade. Just recently I changed to a hydraulic adjustable side link so now I can make adjustments from my tractor seat.
TAYLOR TDF-60S STRAIGHT MAST FORKLIFT (A51246)
TAYLOR TDF-60S...
2019 CATERPILLAR 279D SKID STEER (A51246)
2019 CATERPILLAR...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
UNUSED INDUSTRIAS AMERICA HI-900 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
2016 FREIGHTLINER CASCADIA SLEEPER (A53426)
2016 FREIGHTLINER...
