Question about tractor battery life
/ Question about tractor battery life #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
If you leave the key on in your tractor:
1) will it run the battery down over-night?
2) if it does and you have to use jumper cables to crank it, will it decrease the battery life?
thanks. I just realized I left my key on in my tractor and Im now home 30 miles away from the tractor. Planning on using it tomorrow, just wondering if I should drive back down tonight, or just plan on jumping it in the morning.
/ Question about tractor battery life #2
When you get there take the key out and let it sit for a few minutes.
whether it starts depends on the temperature, If you need the glow plugs to start it then you might have some probems, take the cables.
/ Question about tractor battery life #3
1) Probably not.
2) A one time jump start isn't going to hurt anything.
Some tractors will run the hour meter if the key is left on.
/ Question about tractor battery life #4
It all depends on what you have on the tractor that pulls current. If you have a good battery and all that is on is a dash light, there is a good chance that it will start right up if it is diesel.
/ Question about tractor battery life #5
If the battery voltage falls below 10 volts it will reduce the life of the battery. If one or more cells reverses polarity the battery will have a very short life.
Ended up calling neighbor and asking him to drive over and turn off the key for me. Good neighbors are nice to have.
New/Unused IRMC Massage Chair (A61166)
New/Unused IRMC...
case 370 glass door never installed (A61307)
case 370 glass...
Finn B-70TD Towable Hay Blower (A61166)
Finn B-70TD...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
PREVIEW DATES AND TIMES (A61166)
PREVIEW DATES AND...
