Question about the PTO operation on a MT125 tractor
   / Question about the PTO operation on a MT125 tractor #1
Santafedave
rancho tehama, CA
MT125
I have a MT-125 tractor and I just bought a WoodMaxx TM-86H wood chipper. My question is when I get off of the tractor with the PTO engaged the tractor will shut off for safety reasons how will I work the chipper if I can't get off of the tractor to operate it? Thanks, David.
   / Question about the PTO operation on a MT125 tractor #2
I would think you could wire in a seat bypass switch.
   / Question about the PTO operation on a MT125 tractor #3
Yes , as Doofy said, wire in a bypass switch. It's as simple as a single throw (simple on/off) switch to connect the 2 leads(wires) when the switch is thrown. You can wire it inline so that the seat switch would still work normally when the switch is 'open' (off) then when closed (on) completes the circuit, allowing you to get off the seat. Very simple to do, can even use those 'in line splice' connectors. Hardest part will be where you mount the switch.
   / Question about the PTO operation on a MT125 tractor #4
I have to ask, how did you pick your screen name.. Santafedave? Are you from Santa Fe?
   / Question about the PTO operation on a MT125 tractor #5
Have you tried setting the parking brake, some models this will allow for the pto to operate with out someone in the seat.
   / Question about the PTO operation on a MT125 tractor #6
This is correct. I run my MT125 with chipper all the time. If the brake is engaged the PTO will keep running.
Awesome responses everyone. Countrybumpkin you are right if you engage the parking brake the tractor keeps running. Thanks for all of your responses that is why I love this site! LS mt owner I got my mail name from looking at a BNSF calendar years ago the train had a big santafe on its side and I just added my name. David.
   / Question about the PTO operation on a MT125 tractor #8
Cool, I always liked the Santa Fe railroad color scheme
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2019 Ford F-550 (A55973)
2019 Ford F-550...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
