Question about the PTO operation on a MT125 tractor
   / Question about the PTO operation on a MT125 tractor #1
Santafedave
rancho tehama, CA
MT125
I have a MT-125 tractor and I just bought a WoodMaxx TM-86H wood chipper. My question is when I get off of the tractor with the PTO engaged the tractor will shut off for safety reasons how will I work the chipper if I can't get off of the tractor to operate it? Thanks, David.
   / Question about the PTO operation on a MT125 tractor #2
I would think you could wire in a seat bypass switch.
   / Question about the PTO operation on a MT125 tractor #3
Yes , as Doofy said, wire in a bypass switch. It's as simple as a single throw (simple on/off) switch to connect the 2 leads(wires) when the switch is thrown. You can wire it inline so that the seat switch would still work normally when the switch is 'open' (off) then when closed (on) completes the circuit, allowing you to get off the seat. Very simple to do, can even use those 'in line splice' connectors. Hardest part will be where you mount the switch.
   / Question about the PTO operation on a MT125 tractor #4
I have to ask, how did you pick your screen name.. Santafedave? Are you from Santa Fe?
   / Question about the PTO operation on a MT125 tractor #5
Have you tried setting the parking brake, some models this will allow for the pto to operate with out someone in the seat.
   / Question about the PTO operation on a MT125 tractor #6
This is correct. I run my MT125 with chipper all the time. If the brake is engaged the PTO will keep running.
Awesome responses everyone. Countrybumpkin you are right if you engage the parking brake the tractor keeps running. Thanks for all of your responses that is why I love this site! LS mt owner I got my mail name from looking at a BNSF calendar years ago the train had a big santafe on its side and I just added my name. David.
   / Question about the PTO operation on a MT125 tractor #8
Cool, I always liked the Santa Fe railroad color scheme
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52128)
Kubota SVL65-2...
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
