question about spacer on Mitsubishi D2000ii FD hydraulic screen
   / question about spacer on Mitsubishi D2000ii FD hydraulic screen #1
fordcomanche
Hello,
I recently purchased a Mitsubishi D2000ii FD and have been reading all the great information posted here.
As recommended I pulled and cleaned the hydraulic screen, but have a question about the spacer on the hydraulic screen:
There is a black rubber/plastic spacer between the outer cover and one end of the screen. However the end of the screen going into the housing did not have any spacer, seal, o-ring, or gasket. I didnt see this mentioned in other posts about the screen.
I would like to know if this spacer set up is correct or am I missing seal on the end of the filter screen going into the housing. Attached is a photo of the setup I have.
Thanks in Advance
FordComanche
Does anyone have a photo of the hydraulic filter in their Satoh 630 Bull or Mitsubishi D2000?
(This is the model which has the hydraulic filter screen on the right side under the 4 bolt cover.)
I am trying to determine if the filter in my D2000 tractor is the proper filter.
Please let me know if your filter have a plastic/rubber cap on one end? Is the end cap actually made onto the metal filter assembly or is a separate piece?
I'm hoping to get the filter issue resolved this weekend so that I can use the tractor.
Thanks in advance.
fordcomanche
   / question about spacer on Mitsubishi D2000ii FD hydraulic screen #3
your best bet is to go to this site.
Valley Power
call the number and speak to bill . they deal in these issues on a large scale.
good luck.
   / question about spacer on Mitsubishi D2000ii FD hydraulic screen #4
the filter in the picture works like a air filter. it filters the hydraulic fluid going into the hydraulic pump.Satoh Parts
My d 1850 have a arrangement like this . hope this helps.
Mit,
Thanks for the tips, I found out that the rubber ring is normally attached to the end of the filter.
I had worried that I might have had the wrong filter or dropped/missing some pieces, but it looks like everything is there.
I have flushed the system and refilled and the hydraulics seem to be working very good. It picked up a heavy 5' bushhog with ease.
I will likely get a 4' cutter for normal use, but still needed to be able to move the 5' around.
Thanks again,
Have a great Memorial Day weekend.
2022 FREIGHTLINER CASCADIA SLEEPER (A54607)
2022 FREIGHTLINER...
2013 UTILITY DRY VAN TRAILER (A54607)
2013 UTILITY DRY...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A55758)
2004 Fleetwood...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
