Photogman,
You are right-on with the bush hog issue. Yes, the lifting capability of the 3PH seems to imply that a medium duty 6 footer will be just fine, but tain't so. The Operator's manual has a table that will tell you the maximum recommended size & weight for a 3PH mounted rotary cutter and you will find that for the
L4400 it is 880#. They really should include these tables with the specs they list for the tractors on the web and elsewhere.
I've posted this story here before, but I'll repeat the tale for the benefit of others. It does make the point that tractor specs. have to be taken with a large grain of salt.
I bought a 6' med. duty Woods BB720 (1200#) with my
L4300. The 4300 is the predecessor to the
L4400 and virtually identical in terms of power, weight, size and capability. The dealer warned me that the 4300 wasn't quite enough tractor for that mower and he was right. I went ahead with it because I figured the Ford 4000 would be my fallback point, and it was.
First of all, the tractor does have enough power to run it and the 3PH IS strong enough to lift it. Those aren't the issues. What's at issue is the balance of the combination and (in my case, at least) a 3PH dimensional problem that makes hook-ups very difficult.
With the 720 on the back, it feels like the tail is wagging the dog. The center of gravity of the mower is centered on or near the gearbox which is at least 3 ft. aft of the end of the 3PH arms. The combination of weight (mass) and long moment arm tends to raise the front of the tractor when the mower is raised. You'll need to have the FEL on to keep the front down when you lift the mower....either that or a lot of weights up front. Folks say, you only lift when transporting, so no big deal. I say, if you have to jerk the mower up to get it off a rock, limb, or stump, the last thing you want is to lose steering when the front bounces up instead.
On fast sharp turns, the momentum of the mower can be felt and you wonder how well the 3PH structure is standing up to the stress. I could envision situations where smacking a stump during a sharp turn with that mower might damage the 3PH mounting structure.
Lastly, the BB720 mower is borderline Class II 3PH. To better control the mass of the mower, the pins are spaced further apart and the (non-telescoping) 3PH arms on the
L4300 won't open up enough in width to get over the ends of the pins. I normally have to disassemble one side of the tractor 3PH to get the arms on at hook up. Same thing when unhitching. Once they're on the pins, the width is sufficient, but hitching/unhitching is a bear. Going with Pat's EZ change isn't really an option as it places the mass of the mower another 3-4" aft and you feel it even more when operating.
A 5' Med. Duty mower would be a much better choice. They're still really heavy, but the moment arm of the C.G. will be about 6" less which will help. The Woods BB600 comes in at 1000# so it's still, technically, a bit too heavy. Possibly a Rhino, Bush Hog or JD MX 5 footer would get you closer to the 880# stated maximum. I will say that it is very comforting to have a med. duty mower on when you wade into the heavy stuff. Woods has a new beefed up version of their standard duty mowers out. Think they're called Standard-Xtreme Duty or some such. Lots of HD features without all the weight. Might be worth looking at.
Since your usage is almost identical to mine, I'll include a link to what I use for a grapple on the FEL bucket. It's called the Weslor Brush Claw and it's bolted to the bucket. I got it because it's light, can stay on the bucket all the time, provides bucket load roll-back protection when not in use, and it's manufactured locally. You might have to select "Brush Claw" from a pull-down menu to get to the right screens:
W e s L o r...Excellence in Metal Processing
It's worked out quite well, cause it's always there for me. Don't have a bucket quick-tach on my FEL so a dedicated grapple would've been a pain.
Sorry this is so long. Drank too much coffee this morning and it gave me keyboard diarrhea.
FWIW
Bob
