Question about my L4150 engine idle.
   / Question about my L4150 engine idle. #1
NJDonzi
Farmingdale, NJ
Kubota L345DT
Just wondering if its normal to idle high when you start the tractor when its cold? After about 3-4 minutes it will idle normal.
Thanks!
   / Question about my L4150 engine idle. #2
Thanks!
idling is never good for an engine. The bearing loads are high at idle because of the slow turning of the crankshaft. I always bump it to 1000 or 1200 if I am going to let it sit for a bit or warm up.
diesels work by the heat of compression. when the piston compresses the cylinder of air it raises the temperature of the air to 1000 degrees or so, then fuel is injected into that hot air and it ignites and burns.
so obviously with a cold engine the cylinder walls are absorbing that heat from compression and therefore lowering the air temperature and potentially causing rough running. hence block heaters glow plugs and migration to Florida.
Thanks for the reply. Makes perfect sence. It just does it automatically...like a choke. Wasnt sure if it was normal or not.
   / Question about my L4150 engine idle. #4
Unless your tractor which I doubt has an automatic idle you have something else going on. Does not sound normal to me.:confused:
   / Question about my L4150 engine idle. #5
I'm with Kuboman... I have not seen anything like that on a tractor...
Are you saying the actual RPM is higher... OR it sounds different for the first few min??
Yes, thats whats going on. If you start the tractor it will idle normal. Give it a little gas and it will climb to 1400RPM and stay there for about 2 minutes or so. Then pedddle will come back automatically and idle down. If you just start it without giving it any peddle it will just idle normal. Tractor has only 1248 hours on it.
Then hours later when its still a bit warm it will start normal with normal idle even if you give it peddle.
Over the summer it would start normal when it was warm outside. Just when its below say 50 degrees is when it will idle high 1400RPM's.
Not sure whats going on...all I can say is machine runs perfect other then that.
   / Question about my L4150 engine idle. #7
When you say the peddle comes back, what are you referring to?
   / Question about my L4150 engine idle. #8
Thanks!
Maybe tractors are different. My John Deere 3720 idles faster by itself when its cold when first started and then after a minute it naturally slows down, at 32 deg. When it's cold like 0-10 deg it will start up and run faster for about 3-4 minutes then slow down.
Sounds normal to me.
   / Question about my L4150 engine idle. #9
If I start my L5450 cold without touching the throttle pedal or lever it idles at low rpm. If I speed it up with either the pedal or lever it then idles higher and doesn't fully return to low idle until later. The idle rpm drops gradually as it warms up. I think my L4150 did the same.
Edit - I didn't look in the wsm last night for the idle controller - but I see MichKubota stayed up later and posted the page below.
   / Question about my L4150 engine idle. #10
I have an L4150 and it also starts out at a high idle and after a few minutes backs down to around 800rpm. It is very noticeable and quick drop in RPM. I have only had the tractor for as few months and just thought it was normal operation.
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2008 Ford F450 (A49461)
2008 Ford F450...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
