Question about LT1042 deck pulleys and spindles...
   / Question about LT1042 deck pulleys and spindles... #1
TPajak
UpState NY
Cub Cadet LT1042
I noticed online that there are different versions of my deck pulleys...any reason why they got rid of the the 1 version with both pulleys on the same arm and got rid of the grease fittings on the spindles...I bought mine on Apr 30 2006...this version I have has the tensioner on a separate arm and the spindles aren't greaseable...whats the advantage?..if none, can I swap it over to a single arm design and buy the greaseable spindles?...seemed better the 2 pulley 1 arm design...any help will be VERY GREATLY welcomed...THX
   / Question about LT1042 deck pulleys and spindles... #2
The deck shells are probably the same and you could interchange bolt-ons if you wanted to. I'd just run it as is and replace parts as needed. I've seen 'sealed' spindles last a looooong time. Don't let rope or the like wrap around them, keep them fairly clean and dry and they will last.
Joel
2013 Magnum Power MLG08 Towable Light Tower (A55851)
2013 Magnum Power...
2001 International 4700 Bucket Truck, VIN # 1HTSCABNX1H380565 (A54865)
2001 International...
16' Cattle Guard (A53316)
16' Cattle Guard...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
