CoyPatton
Veteran Member
- Joined
- Aug 10, 2015
- Messages
- 1,598
- Location
- Poplar Bluff, MO
- Tractor
- Yanmar YM2002D with Koyker 110 FEL
Thanks for the quick response! That is awesome news! Can't wait to take delivery of the new tractor!
One issue is that few tractors run the hydraulic volume or pressure if a skid loader. Nor are as compact.
This has 2 big consequences.
1) if the implement requires a flow rate (volume) as a min flow rate greater than your tractor supplies, the implement may not function at all
2) very related—since tractors FEL’s are much longer than those on a skid steer, their lift capacities are often much lower than a skid steer. Many skid steer implements may be much heavier than the tractor related attachment. So while it may attach and should if you have a standard SSQA installed on your tractor, you may giving up working weight to implement weight.
So borrowing these implements may not be in your best interest for the work you need to get done.
